Question about Dishwashers
Don't know how to put it back on wash,as it stuck on dry.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 119 Answers
TRY TO TURN OFF POWER 4 1MIN IF THIS DONT WOK CHEAK OAMS ON HEATER COIL AND THERMOSTST
Posted on Jan 31, 2010
My washer won't spin. There is a coin stuck inside
If the coin is in between the 2 drums but is free floating you amy be able to get it by removing th bottom drain hose from the drum but this can become a pain unless you are lucky as the coin will move with the machine tipped over. the other way is to remove the heating element while the machine is upright and use a stick or a grabber to get it out.
Dec 30, 2012 | Washing Machines
Hello i have a quinny buzz 3 and will like to wash the seat. dont know if i should put it in a washing machine pls.
Good Morning
Spot cleaning should be done by mixing warm water with a mild handwash detergent and using a clean sponge on the fabric taking care not to make it too wet as this may cause water marks.
If you really want to wash the whole fabric you can do so; Remove it from the sub seat (seat frame) to wash. Handwash is best, but if you have a handwash or delicate cycle on your washing machine this may be used. Maximum temperature 30 degrees, using a mild detergent and if possible do an extra spin following washing to make sure most water is out of the fabric. Then to dry don't put it in a tumble drier as this can cause mis-shaping, instead leave to dry naturally (not in direct sunlight as this can cause discolouration) and make sure fabric is fully dry before putting back onto unit for use as damp areas can cause mould or mildew growth.
Jul 24, 2011 | Quinny Buzz Three Wheel Stroller
Not receiving power to unit... was having a camera button stuck but now no power....
Bartteries have probably drained, unscrew or unclip it clean thoroughly, remove all grease debris etc, put back together and put in new batteries. You can wash all the plastic parts and keypad in warm soapy water and rinse dry well. Clean the circuit board with isopropyl alcohol. Don't wash it!
Jan 27, 2011 | Sony RM-BR300 Remote Control
FP fault 43
code 43 is an out of balance switch problem.Once replaced, would fix the issue.
One trick that might work ;-
I unscrewed top cover, then unscrewed and lifted up the grey computer cover. The balance switch is underneath on the right with a yellow and white wire coming off.
I removed switch from clip and then removed the wires/clips from contacts. There was definitely corrosion on the contacts. I soaked switch overnight in vinegar. Then rinsed with water. Then dried switch out for day.
Put it all back together and am now on second load of washing.
Thanks.
Jul 01, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Can i wash my covers
sure, remember to only dry with a light air tumble. not extreme heat. the full heated dry will cause shrinkage.
Mar 01, 2009 | Graco ComfortSport 8639 - Grey
Dryer
It sounds as if you have the dryer button pressed in before you start the wash! If you don't. it is likely it is stuck in or the switch is shorting out on the back. Unless you are a competent DIYer, find someone who is to check the electrical connections and test whether the switch is working correctly.
Sep 14, 2008 | Ariston Technologies Ariston AWD12 Front...
Assembly
Hi there!
Try dampening the fabric again (leave on the line on a showery day etc) and put them on again.
Washing may have shrunk them, but dampening will help soften them again.
When on, dry indoors.
Please rate as Fixya if this helps you, as "helpful" is for 70% and below.
Thanks.
Jun 14, 2008 | Baby Gear
Blinking Quick Rinse
brent, After doing a little research on this model, I see that Sears put out a service flash concerning this problem. Dishwasher stops in mid cycle and one or more of the lights are flashing. SF22-715. The correction is to replace the existing board with an updated board that controls the line voltage better. Part number 8530928. You could be covered under this flash. The tech will have to eliminate the possibility of a stuck or shorted keypad which will cause this same effect. You can try to get this back in operation by pressing in this order: high temp wash-air dry-high temp wash-air dry. This will put it into a self test mode. Just let it run through if it works. If you don't have those keys try power scour-air dry-power scour-air dry. Catriver...post back.
Nov 19, 2006 | Kenmore 16639 Built-in Dishwasher
Drying time knob broke
You should be able to simply push the new knob right on the switch shaft. If part of the broken knob shaft is on the switch, remove it first before installing the new knob. If you see that the switch shaft is broken off, replace the switch as well. Hope this helps.
Aug 07, 2006 | Hotpoint Aquarius WD63 Front Load...
Dishwashers Logo
Top Dishwashers Experts
