Question about Sennheiser Evolution G2 100 Series UHF Handheld Microphone System (A) EW135PG2A Microphone
I have a Sennheizer evolution g2 transmitter and reciever to go my Sony EX3 - but the input level is too low - could this have to do with the frequence I'm on?
    Champion:
  • 211 Answers
It got nothing to do with the frequenty.
You can adjust the microphone gain in the handheld-menu. You can also adjust the receiver-output gain in his own menu.
Good luck,
Gerard
Posted on Jan 31, 2010
Comme on RESET LAMP Videoprojecteur SONY VPL EX3 procedure ?
You can reset lamp timer of VPL-EX3 by following procedure.
Connect power cord in wall socket, standby indicator will lit red.
Press following keys on projector remote.. RESET, Left arrow, Right arrow, ENTER
Lamp timer will reset.
Hope this will help.
Thanks.
Mar 22, 2011 | Sony VPL-EX3 LCD Projector
Sennheiser em100 g2 receiver passes major static to mixer
This is a well known problem with the EW100 series that is easily solved.
You will need to run this reciever into a line input via a mono(TS) jack to jack lead. this will bypass the phantom power.
Make sure that you set the AV OUT to +18 in the reciever menu to get optimum level.
Phantom power is only present in the microphone inputs XLR3.
Hope this helps.
Rus.
Mar 01, 2009 | Sennheiser EM100G2 RACK MOUNT G2 RECEIVER...
Transmission distance problem on Sennheiser G2 wireless
I regularly use G2 ew100+300 systems, which have a manual squelch adjustment on the reciever. Squelch is difficult to explain but here we go: a squelch adjustment gives you the options LOW, MEDIUM, HIGH these settings effect transmission distance and interference rejection. for example: a HIGH squelch is less prone to interference but has a shorter transmittion distance. A LOW squelch is more prone to interferance but allows for a longer transmission distance. For most applications, a MID squelch is fine. If this does not help- the next option would be to swap arials between units and see if the problem moves. The G2 series are a 30mw transmittion which has an effective range of about 50m
hope this helps.
Rus.
Feb 15, 2009 | Sennheiser SK 300 G2 Wireless Bodypack...
All four hand held systems failed
check out override frecq see if you can change transmit and recieve switch settings ie dip switch sets sombodys overiding your freks
Dec 17, 2008 | Sennheiser Evolution G2 100 Series UHF...
All four hand held systems failed during a performance
Hi kb
That is an odd encounter, and most probably one of the R.F.I. kind. Radio Frequency Inference can be caused by many things. Sometimes it can be a nearby piece of equipment creating that much interference, that the mics could not operate. It may have been a spurious mobile radio transmitter as used with two way radio for the cops, ambo's, firies,or even a nearby Cab!! Some times faulty light dimmers can also spray RF.
To what ever end, the fact that 4 mics went down together is indicative of an external problem, and being radio mics, it would have been radio interference.
The only other thing to check is that they are UHF. there are many VHF mic systems still about, but these frequencies are now being used as part of the soon to be introduced digital TV transmission. Best check that they are UHF, The VHF type have actually been illegal for a number of years Hope this info has helped you understand your problem. I am happy to answer any questions you may have. Cheers
regards
robotek
Low Battery Indicator
No worries, thanks for getting back to me. Another questions for you. What sort of batteries are you using. Are they rechargeable, alkaline, carbon zinc, or the Sennheiser BA 2015 accupack rechargeable.
Oct 27, 2008 | Sennheiser SK 300 G2 Wireless Bodypack...
Need asistent
my sony vpl ex3 will not light up, has a lamp/cover light on all the time can somebody help
Jun 21, 2008 | Sony VPL-EX1 Multimedia Projector
Very bad hiss even when power is turned off and battery is removed
If you use a sennheiser check your Squelch is not set to high / low. I use a Z1 and that solved my problem.
Feb 07, 2008 | Sennheiser EW100ENG-G2 2-Way Radio
134 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
