Question about Mitsubishi WS-55859 55" Rear Projection Television
After power outage tv wont come back on. tried reseting tv, unplugged, everything but timer light continues to blink
  • Mitsubishi Master
  • 5,807 Answers
here is your guide:
while i am looking for your schematics, take a time to read the link about
flyback
and post the things you have done to remedy the cause.
It will indicate flashes or continues flashes, and it may helps us
find the possible causes of it.
There could be many reasons. But, more Often, it would be
on the Circuits Board. You need to Open the TV, unplug the
wires from Circuits Board, pull it out and check it.
More often, you would find either a Loose Solder
connection or Leaked / Bulged / Swelled capacitor. You
need to note down the part number and you could order it
online or go to your Local Electronics shop and
purchase it. Once you solder it, it would be all set.
hope these helps initially , regards
Posted on Jan 31, 2010
  • Rommel Cana
    Rommel Cana Jan 31, 2010
    here is additional info
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Blinking "Timer" light for WD-62725
If this is a DLP, you may have problems on the FMT/DM boards in the sealed electrical chassis.
That's a big problem, because Mits doesn't make the DM/FMT boards available anymore. They are only available for rebuild from Mitsubishi and other qualified places.
There is a chance that there are some vented capacitors on the DM and FMT boards you might be able to replace, but it's for someone really comfortable with completely disassembling a set, soldering in 8 new caps and rebuilding the chassis.
Rebuilds will run you $400-$500 in rebuild costs and an additional $200-$400 in labor, depending on the joint.
Jul 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
The tv turns on and back off and the on timer light blinks on
Try to reset everything in the menu section to reset the timer for tv some how was activated and needs to be turned off.that might help!!
Mar 01, 2009 | JVC AV-27920 27" TV
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
