Question about GE Profile DPSB619ED Electric Dryer
My White Knight sensordry tumbledryer has been making a loud banging noise, (like there are shoes banging about). Is it a bearing problem? Is it a problem that i can fix?
Sounds like the bearing carrier has come away from the drum-same as mine,seems to part of the drum
so not available seperately-its riveted on not bolted,mine has deformed and enlarged the rivet holes in the drum so a repair dosent seem practicle if yours hasnt chewed itself up then you may be able to replace the rivets with nuts and bolts and maybe change the bushing kit for about 6 quid
Posted on Dec 30, 2010
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
I have a tumble dryer white knight 77aw and it makes a loud noise like a engine could u help
Hard to tell but from what you're describing sounds like bearings for the barrel.
Mar 17, 2015 | Dryers
The high and low temperature buttons on my White Knight sensordry tumbledryer pushed in because a screw had become loose inside. Have dismantled it but can't work out how to reassemble - there is a little...
Tiugh one. Next time take a photo of the site before you try to take it apart. Or have someone send you a parts break out of the machine. Good luck.
Oct 16, 2013 | Dryers
White Knight sensordry tumble dryer which only works on low heat
Could be element or thermostats, element is twin giving two heats ie !00watt/ +1800watt, possible one side has gone, you bcan check with multimeter and compare readings..Good luck
Oct 01, 2009 | Dryers
Maytag dryer making a loud banging sound
are there shoes in the dryer?is the dryer level?
Aug 16, 2009 | Maytag PYE2300AY Electric Dryer
Tumble Drier does not heat - Its a white knight. What would be the likely cause and is it repairable?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Nov 01, 2008 | Dryers
White knight tumble dryer making banging noises when spinning
I have this banging problem, it sounds like a plastic ball rolling about inside it
Aug 25, 2008 | Dryers
GE Profile DPSB619ED Electric Dryer Logo
520 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
