Question about Microsoft Windows Vista Home Basic Edition for PC
I keep getting a rundll error i am unable to run internet expoler
  • 22 Answers
This problem could have happened due to an incorrect program removal procedure. You can hence try to fix it by installing the program that has been removed and to correctly uninstall it either with the Uninstall option proposed by the program itself or through the Add/Remove feature found in the Control Panel menu.
  • 1. Go to the Start menu and open Control Panel
  • 2. Select Add/ Remove program option and locate for the program that you want to remove and click Remove.
  • 3. When the procedure is over, delete any shortcuts that could have stayed and empty the Recycle Bin.
  • 4. Reboot your system
Posted on Jan 31, 2010
Testimonial: "thank you now working again "
Is the module RunDLL very useful?
It is essential to run many windows programs.
More info required to give an answer
Jul 09, 2014 | Acer Aspire Computers & Internet
How to fix a runDLL error at s?tartup
yes in this case specific service will not run or supported in this case u have to insert bootable cd in cd drive and run setup and select repaire system.
Jul 08, 2014 | Acer Aspire Computers & Internet
Everytime I start up Windows I an error message.
Well, the reason causing Rundll Error is probably that when you are surfing on line, some Trojan and malware attack your PC and modify the registry for malicious purpose. Though the anti-virus and anti-spyware can remove those Trojans and malware, they cann't repair the destroyed registry. So, Rundll Error happens! Of course, Rundll Error is not only caused by Trojans and malware. According to our research, mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause Rundll Error.
Thru serious test of our expert team, Perfect Optimizer can fix Rundll Error 100%, much higher than other registry products.Because Perfect Optimizer uses a high-performance detection algorithm that will quickly identify missing and invalid references in your Windows registry. With a few easy steps Perfect Optimizer will entirely scan your Windows registry for any invalid or obsolete entries and provide a list of the registry errors found. After that you can choose to clean list items with selection or automatically repair them all.
So when your PC got Rundll Error, it's highly recommended that you download Perfect Optimizer and repair Rundll Error. Anyone can do it like a computer guru within 5 minutes!
Jul 14, 2010 | Toshiba Satellite P105-S6227 Notebook
How do i remove run.dll2 from my computer?
Rundll.exe files are programs that are directly tied to the registry on Windows computers. Dynamic Link Library (DLL) files contain libraries of information used by other programs running on your computer. They were originally created in order to help computer programs run faster on the Windows operating system. When a DLL file is corrupt or missing, a Rundll error will be generated. Normally when a rundll error is generated it is related to malware.
  1. Note the process that is generating the Rundll error by examining the last file name in the error that ends in ".dll."
  2. Open the service configuration program on your computer by selecting the "Start" menu and typing "command" in the search text field. At the DOS prompt type "services:msc" and click "Enter."
  3. Select the DLL service from Step 1. Right click the service name followed by the "Stop" menu button. Exit the service configuration program.
  4. Open your computer's registry editor by typing "regedit" at the DOS prompt and navigate to the Rundll registry key by typing "Microsoft\Windows\CurrentVersion\Run" in the Search field.
  5. Select the registry key returned and in the value associated with the registry key, confirm it ends in the same DLL file name found in Step 1. If it does, single left click the value and Press the "Delete" key. Exit the registry editor.
  6. Restart your computer and the Rundll error will be corrected.
Save a tree.
Apr 28, 2010 | HP W19b LCD Monitor
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
RUNDLL Error Message, Windows XP
Dear sir,
Welcome to Fixya.
Rundll error is observed when computer is attacked by viruses and spyware.I think your computer is infected by virus and spyware.You can remove the viruses and spyware by using good Antivirus software,but if you want to get rid of all errors permenantely, solution is format your pc and reinstall your operating system then install good antivirus.
I think it helps
if you have any problem regarding this issue leave a comment or feedback we were happy to assist you.
Have a Nice Day!
Oct 02, 2009 | Dell Dimension E520 PC Desktop
Cannt do any thing
use a good antivirus software to scan the machine. you may have a Trojan.
Trojan usually use the rundll to install itself.
Dec 01, 2008 | HP dc7800 Business Desktop USDT Alternate...
RUNDLL Error loading c:/PROGR-1/MYWEB-1/bar/2.bin/M3PLUGIN.DLL The specified module could not be found Can you please help me how to get rid of this at the start up please. Thax Tracie
This is a virus download " Malwarebytes " and install and run it will delete all virus files
Usually picked up downloading cracks
Get a decent antivirus suite to protect your computer
A lot of them have a free 15 to 30 day period
Aug 20, 2008 | Intel Motherboard
Microsoft Windows Vista Home Basic Edition for PC Logo
73 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
