Question about Ariston Technologies Dishwashers
Ariston LI 45 door will not remain closed and will
Our Ariston LI 45 door will not remain closed and will not catch on the latch. Therfore it will start the dishwahing cycle with door open
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Posted on Jan 02, 2011
Door locked shut
Hi found myself in same situation. Press in latch and insert fingers upwards there is a grey plastic strip push this up with fingers and door should open. Note upward press needed where this catch meets front of machine so just slide fingers up from latch/handle. There's actually no need to take top off to enable this.
Dec 27, 2013 | Smeg STX2 Dishwashers
How do I stop cycle and unlock door?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 27, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
My kenmore elite with digital face wont start. just beeps when you hit the start button
If the washer beeps when you are trying to start a cycle, the control believes the door is open.
First of all check the hinge area, the door seal and latch/catch area to make sure something is not in the way of the door being fully closed. If it is closing fine and nothing is obstructing, you will most likely need to have the door latch mechanism replaced. If you can send me the full model number from inside the door I can get you an idea of what this might cost.
May 03, 2010 | Washing Machines
Door catch
Hi.
Usually the spring is not sold as a single part.
You will need to replace the door lock.
Regards.
Nov 20, 2009 | Dishwashers
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Door will not close, can't see that catch is physically broken?
Could be that the latch is triggered but is not around the latch bar. Happened to mine. Had to pull the door liner but still took less than 20 minutes. Keep track of which screw came from which hole.
Aug 19, 2009 | Ariston Technologies L63 Free-Standing...
Door latch broken
Look in yellow pages if you are in the U/K, and ring Hotpoint service, who are the service agents for Ariston.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Ariston diswasher trips out as soon as door closed
hi On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
Oct 13, 2008 | Ariston Technologies L63SNA Stainless...
I own a Kitchen Aid KUD102frss dishwasher. The door is not closing properly. It appears to be the latch. The start button blinks
you might have started a cycle and opened the door by mistake.  try pressing HI TEMP, AIR DRY, HI TEMP, AIR DRY close door to latch, press cancel.
it worked with mine.  you can give it a try.
Aug 20, 2008 | KitchenAid Dishwashers
Dishwashers Logo
333 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
