Question about Sharp Office Equipment & Supplies
Our AL-1000 has an error of H 4 on the screen and no buttons are working
    President:
  • 3,085 Answers
You will have to replace the FUSER. H means heat.
Posted on Jan 31, 2010
My Sharp AL 1000 is displaying alternatively the letter H and the number 4. What should I do?
Hello
The error that is on your disply is the following.
The fusing temperature does not reach 175 degrees celsius within 30 seconds of turning on the power, or the fusing temperature keeps at 140 degrees celsius.
In sequence press the following buttons [clear]-[density select]-[clear]-[desity select] the display will go blank.
With the copy quantity keys input 14 and press the start/print button, the machine will cycle.
If the error returns then the thermistor and themo fuse will have to be rplaced.
I hope this helps you
Regards
Apr 16, 2011 | Sharp AL-1000 Copier
Sharp AL-1000 error E7
E7 is CCD drive circuit trouble. Refer to the manual
obtainable from mauritron
Feb 21, 2011 | Sharp AL-1000 Copier
After putting on the copier the scan lamp carriage is vibrating for about 3 to 4 minuet then after the code e7 came.
You need to clear the code, press the following buttons in the order below.
  • Clear Key (far right key)
  • Exposure Key (far left key)
once you do this correctly the screen should go blank. Type in the following
  • 14 (using the copy quantity keys)
  • Press your copy key
  • 1 (using the copy quantity keys)
  • C (until the machine restarts)
If the code comes back then you are having a reference error and will need to call a local Sharp Authorized Dealer to service your machine.
Oct 09, 2009 | Sharp AL-1000 Copier
How can i remove H 4
Press c> photo>C>photo press 14 press start/Print key
machine ok
Oct 08, 2009 | Sharp AL-1000 Laser Printer
Polar F11F Error 16
you need to hold down all 4 or 5 buttons at once. This will reset your watch and bring up the message "welcome to polar fitness world". Press ok button 1x to start your setup process.
Apr 16, 2009 | Polar F11 Heart Rate Monitor
Blinking h then 4
The error H and 4 blinking indicates that, You have a defective fuser unit.
H is for HEATER
You should replace youe heater unit, if your product falls in warranty period, you can avail wrranty..
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Apr 10, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Sharp AL-1340 Scanner hangs up, grinding sound, with E-7 code
The scanner rails will dry out. Try a drop of oil on the rod the scanner travels on. There are two bushings that slide along the rod/rail. Good luck.
Nov 10, 2008 | Sharp AL-1000 Copier
AL-1000 H4 error
Try this:
to reset enter buttons clr, exposure, clr, exposure, the display will blank, enter 14, press prnt button, then clr several times to get out. This may work, if not then you definately need a fuser. Where are you located. Maybe I could send you a used one if this doesnt work.
Jul 18, 2008 | Office Equipment & Supplies
AL-1000 Sharp Photocopier
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 11, 2008 | Sharp AL-1000 Laser Printer
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
