Question about Nokia E63 Cell Phone
Auto find on home screen - Nokia E63 Cell Phone
All of a sudden my 6s speaks the letter as I type, how to I turn this off?
  • press the "HOME" button on your iphone..
  • tap the "settings" icon on the home screen
  • tap "general" and then tap "accessibility"
  • tap the "speak-auto text" option to off to stop the iphone from speaking s you type....
  • press the home button to return to the home screen.
Hope it works
Mar 05, 2017 | The Computers & Internet
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
How go I rotate my tablet to vertical
1. Tap on the top right corner of the Home Screen to access the tablet > utilities.
2. Tap Settings > Screen.
3. Tap to deselect/select Auto-rotate screen.
Oct 19, 2014 | ASUS Eee Tablets & eReaders
My Samsung Nexus S won't auto rotate.
Can you supply more information please? For example, when will it not auto rotate? In certain apps? On the home screen? etc.
Dec 17, 2012 | Samsung SPH-M610 Cellular Phone
I do not know how to set the timer on the B60
OK - here you go:
1. Hit your menu button
2. The first prompt is to set the clock, if you do not need to reset your time - then just hit the menu button again.
3. Your next prompt is for auto off, this'll set it to cut off after a specified time. However, you also want it to come on at a specified time right?
4. Hit menu again. This takes you to auto on/auto off (a.k.a. your timer). From here simply use the buttons to the right or left of the menu button to set the time (watch out for am/pm).
5. Flip thru the last 2 menu options of brew temp & brew size. Make any changes you want to there.
6. Finally you'll end up back on the home screen - if you set the timer, then you will see "ONOFFTIMESET" on the home screen.
Jul 12, 2011 | Keurig B60 Coffee Maker
How to tune channels first time when you purchase a new Sony Kdl 32EX600 LED tv?
Hello
Do connection to the antena if you wants to set the TV auto tuned.
During this initial setup, you can perform the following:
1 Select the language for the on-screen display text.
2 Select HOME or Retail mode. [Here you have to select "Home" mode if the set displays "Retail"
3 Connect cable or antenna, then select OK to run Auto
Program
• If you have cable and antenna available, please connect cable first.
• IMPORTANT: Auto Program is only effective when cable or
antenna is connected. If you cancel Auto Program before completion some channels may not be
available.
4 Auto Program will scan for available channels from the signal source directly connected to
the TV's CABLE/ANTENNA input and may take sometime to complete the process. Follow
the help text provided on the screen to run Auto Program.
OK.
Feb 23, 2011 | Sony KDL40EX600 TV
A flashing message saying auto adjustment. how do i get rid of it please
on your Monitor the should be an auto-adjust button. Press it. or try and change the screen resolution.
Jun 13, 2010 | Microsoft Windows Vista Home Premium...
How do I auto set up for my zoooos controller
Auto Setup automatically searches for the right code for your DVD player. For the most popular DVD player models, Auto-Setup takes a few minutes or less, however, less-common models can take much longer or this method may not work at all.
  1. Find the Auto-Setup instruction page in the on-screen Setup Guide. Your DVD player must be on the Auto-Setup instructions for this method to work properly.
  1. Engage Auto-Setup mode: Hold down the Red button until the setup light turns off. Continue holding the Red button and press the Yellow button three times, then release both buttons. If you’ve done this correctly the light will turn back on and remain on until setup mode is exited. When the setup light remains on, the controller is in setup mode.
  1. Wait for a message from your DVD player. Even though you can’t see anything happening, the controller is actually loading and testing various codes. When the right code is found, your DVD player will tell you to press the Home button. If your player doesn’t respond within about 10 Minutes or the time on the estimate chart, press the Home button to exit this method, and use the Direct Entry method instead.
  1. When the DVD player instructs you to press the Home button, be sure to do so before the onscreen timer runs out. If you miss pressing the Home button before the timer runs out, go ahead and wait until a message from the DVD tells you what to do. If you have not yet pressed the Home button, the DVD will instruct you to press the Back button to back up to the code you missed.
Jan 09, 2010 | Fun Rise Zoooos DVD System
Auto adjust in progress what is it and why ?
Sir,
Auto Adjust is a screen resolution adjuster which automatical adjust the resolution of graphics according to screen. to get rid of it you would require to install the drivers of your graphic card of mother board or any else.
Oct 18, 2009 | Microsoft Windows XP Home Edition
Auto lock
just switches screen of to save power and avoid accidental icon selection on pressing the 'home' button at bottom of iphone you are presented with a slider on screen to turn back on.. can be pascode protected and set to auto lock after a certain time. I dont use it in stead I use manual lock (button on top right of iphone
Aug 03, 2008 | Apple iPhone 3G
Nokia E63 Cell Phone Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
