The air condition does not produce enough cold. I have been using it for one year now but the problem just started today (i have put it to the minimum temperature of 18 centgrade...
  • 111 Answers
It sounds like it's due for a good internal cleaning, they get dirt and such in them, it plugs up the condensers(2), you should be able to remove the inside cover and see without too much problem, don't force it,gently use a soft old toothbrush and clean the fins, don't bend them
Posted on Jan 31, 2010
Water is leaking on the ground by the firewall
Year, Make, Model, and Engine Size?
Have you you been running the air conditioning? It is normal for water to drain from the EVAP housing when the air conditioning is on. Since the EVAP Core gets very cold moisture from the air will condense on it. Eventually enough water will build up and it will start to drain via the EVAP drain. Typically this is done through the firewall on the passenger side on many vehicles.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 13, 2014 | Cars & Trucks
Air condition is not putting out enough cold air
there are tools to clean the system out and refilled whit freck licuid.
nut you cant do it yourself.
May 05, 2014 | 2002 Jaguar S-Type
Heat doesnt work in my jeep cherokee when driving but when sitting heat works
Put a piece of cardboard in front of the radiator. Only if it's cold out though, Usually in really cold weather, the cooling affect of the cold air circulating around the radiator keeps the fluid from getting hot enough to produce heat unless your running in park.
Dec 17, 2013 | 1998 Jeep Grand Cherokee
MY CAR'S AIR CONDITIONING ISN'T WORKING. MY SON
mcdevito75 here, either your son in law didn"t put in enough freon or the compressor is not working, Have your local shop check it out.
Jun 18, 2010 | 1998 Cadillac DeVille
I have 2004 audi tt and today it started overheating i let it cool down and again it did it again overheated within 5 min
You're in the wrong forum for this problem, however since it has overheated you should replace the thermostat. You need to determine why it overheated so check the coolant level and replace/replenish as necessary, check the fan relay(s) for correct operation and check the fans themselves for operation. Just finding one problem and correcting it does not mean that it is the only problem as all the items that I've mentioned will cause overheating, but they are also symptomatic of an overheating condition, so be sure to correct any deficiencies before moving on. Also, should you start to overheat, put on the air conditioner as, if the fans are working, it will draw cooling air through the radiator and assist in lowering the engine temperature. Set it to warm if it's cold out and cold if it's hot out. If this fails to provide an air flow put on your heater and set it to high. If neither operation produces an airflow, whether overheating or not, then neither of your fan assemblies are operating. You failed to state under what conditions this occurred so should it happen again use the a/c first and switch to heater if the a/c trick doesn't work. The first idea will draw air through the radiator, and the second will draw it through he heater core to aid in lowering temps. I'd suggest that you include a lot more detail when describing any automotive related event, as you can never have too much info.
Mar 13, 2010 | Audiovox Heating & Cooling
05 Lincoln LS 3.0 V6. Outside air temp 32F. Idle decay when cold
This sounds like you have a pcv hose that has become an open vacuum leak. It is located under the upper intake, or given the year your air filter box may not be correctly sealed and possibly have a mass air flow sensor concern. Any Check engine light or codes to work with ? I f you have further questions just leave a comment on my page,
Jan 10, 2010 | 2001 Lincoln LS
Don't know how much water to use
Do not put any water in the unit, the water that is in the unit drawer or bucket that is attached to the hose is a byproduct of the air conditioning process.
It transfers heat to cold and in the process produces condensation = Water.
May 30, 2009 | Everstar Portable Heater/Fan
Air condition want cut off automatic
Hello, It sounds like your unit is going into defrost mode. Heat pumps struggle below 35 degrees F. Make sure the coils are clean so the unit will work at peak performance. They do make a heat strip to put in these units to help with cold temperatures. If you need more help just ask. Good luck.
Jan 23, 2009 | Whirlpool ACE244XS Air Conditioner
1994 Pontiac Grand Prix blows cold air on feet
ck to see if there is vacuum at the control head and if there isnt ck for incoming vacuum from the motor
Jul 03, 2008 | 1994 Pontiac Grand Prix
No water
If the air conditioner is putting out cold air, don't worry about it making water. You may not have enough moisture in the air to produce more water than it requires.
In some types of air conditioners, the water taken from the air is used to assist in cooling the condenser unit. The excess is run off.
Jerry G.
Jun 21, 2008 | DeLonghi CF210 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
