Question about HP Pavilion dv6000z Notebook
My cd rom drive doesnt work. It says it has a code 19 error. How can i fix this problem. Thanks
    Problem Solver:
  • 14 Answers
Try system restore about 30 days usualy does the trick and you dont lose any of your documents
Posted on Jan 31, 2010
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
Code 19 on e-machine cd rom
Click the "Start" button, click the "Run" option and then type "regedit" and click the "OK" button. Use the navigation pane on the left side of the window to navigate to the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} Select the "UpperFilters" key in the right side of the window, then click the "Edit" button and then click the "Delete" option. Click "Yes" to confirm the deletion. Click the "LowerFilters" key, then select the "Edit" button and choose the "Delete" option again.
Click "Yes" to confirm the deletion. Close the Registry Editor window and restart the computer to finish applying the settings that should fix the Code 19 error. Hope this helps.
Dec 01, 2012 | E-Machines emachines (emachinees) CD-ROM...
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
Code 19 error in sony cd rom.... wat is the solution for this.
Your CD drive or DVD drive is missing or not recognized by Windows or other programs. Windows has a "Fix it" for this located at http://support.microsoft.com/kb/314060.
Mar 01, 2010 | Sony (2450455) CD-ROM Drive
Cd rom not working error code 19 acording to device manager .this is on acer aspie x3200. it will not run a dvd or cd on windows media player . have set all defaults to windows media player
To run a dvd on windows media player you need the corect codec, it is better to use "power dvd" or somethign to watch dvds. For the cd drive not working, this error code means it is not been reconized. Try doing the following. goto control panel and system, then goto device manager, uninstall the cdrom drivers and restart pc, maybe this will clear the conflict. Here is also a link to a fix programme by microsoft that will try fix your cdrom for you. click here
follow the instrsuctions and it will clear your regsteries and all for you, hope this helps
Nov 28, 2009 | Computers & Internet
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) Laptop Levono y530, device dvd rw optiarc AD-7580s I tried to uninstall & reinstall it, but...
Give this a whirl:
CD-Rom stops working. After checking device manager you find an exclamation mark on the drive. It doesn't mean the drive is dead. It could be an upperfilter or lowerfilter registry issue that is keeping you from accessing the cd drive.
This fix worked for my client:
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Also, try this fix from microsoft.
CD-ROM access is missing and messages cite error code 31, code 32, code 19, code 39, or code 41.
Try this before replacing the drive and remember that you may have to reinstall some burning software.
Oct 16, 2009 | Lenovo IdeaPad Y530-5243U
My cd/dvd rom has stopped working it says that the driver is ok but there is a (code 19) stopping it working any help gladly recieved many thanks
Please roll back your driver or you need to reinstall driver from driver CD i think this is helpful to you if this solution is not solve your problem then plug out your CD ROM and replug CD ROM properly
Oct 04, 2009 | Computers & Internet
How to solve the code 19 errors
Error Code 19 means that the registry is corrupted. Try the following fix:
  1. Click Start and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters. On the Edit menu, click Delete.
  5. When you are prompted to confirm the deletion, click Yes.
  6. In the right pane, click LowerFilters. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. Exit Registry Editor.
  9. Restart the computer.
If this does not work, try uninstalling and reinstalling the computer by:
  1. Click Start and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
    In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
  3. When you are prompted to confirm that you want to remove the device, click OK.
  4. Restart the computer.
Nov 22, 2008 | Sony (2450455) CD-ROM Drive
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
