Question about Microsoft Xbox 360 Controller
My xbox 360 carnt read my discs that well i carnt play 3 levels on my xbox for cod 5 but my friend can play all levels and runs alot faster
    Problem Solver:
  • 7 Answers
Could be a laser problem call microsoft and tell them the issue, They will most likely tell you to send it in to be fixed. If you do not have a warranty this can cost 90USD.
Posted on Feb 02, 2010
I am getting the error "this disc is unreadable" when inserting COD MW2 into my first xbox. When I insert the disk into my second xbox I do not have any problems playing it. I borrowed another...
I have actually had the same problem myself. First you should try removing your Hard drive to see if that is what was causing the problem. If that isn't it then clear the cache by going to: System Settings -> Memory -> Device Options (Press Y while you are highlighting the proper storage device) -> Clear System Cache Try to start the game after that and should it still not work then try to install the game to your Hard Drive by inserting it at the Dashboard, pressing Y to access "Game Details" then "Install Game". If none of this works then you may have a faulty disc drive which you would need to contact Xbox Customer Support about.
Jul 17, 2011 | Microsoft Xbox 360 Console
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
How can I make my Xbox games load faster? One of my friends always loads way before us.
You can make games load faster on the Xbox 360 by installing it to your hard drive. Loading times are reduced because reading from pre-installed content on a hard drive is way faster than reading from a DVD disc. Installing is easy. Go to the dashboard, and scroll to where you would normally start the game from. But instead of pressing A to play the game, press Y on it and you should have the option to install it.
Apr 10, 2011 | Video Game Consoles & Games
Xbox wont read discs
Does your friend smoke cigarette?
2 possibilities:
1st: he smoke a lot and the lens is dirty.
2nd, he plays a lot and the lens is end of life.
You can first try to open it and clean the lens with 90% alcool.
you use a q-tip and smoothly on the lens
If it doesn't make it find a replacement lens. (it's not that hard to install)
here you can find that for 6$ free shippping
http://www.dealextreme.com/details.dx/sku.19087
You can also try to sell it that way it's not a major problem for someone who feels comfortable with the inside machine.
good luck!
Nov 07, 2009 | Microsoft Xbox 360 Console
When i play my friends on fifa 09 they seem to run alot faster than i can.
the wiring on the controller may be faulty try swapping controller with your friend or you may have to press a trigger button to run fatser
Jul 12, 2009 | Video Game Consoles & Games
X-box 360 won't read discs
sounds like the reader lens has burnt out on it .is your xbox stood upright ? seem to hear the lenses burn out alot faster if the consol is upright as opposed to being led down, you can buy the parts from ebay or other computer shops , or send it back to microsoft to repair , you are able to lay downloaded games as they play off of the hard drive memory , where as the disc games obviously read off of the disc when the laser gets tired they work intermitantly then eventually stop all together.
hope this is of help to you
kind regards
bert31000
Mar 19, 2009 | Microsoft Xbox 360 Console
Xbox 360 leaves scraches on my game.
if your 360 is still under warenty with microsoft they will replace your games and your system. give them a call. If its not under warenty you will have to purchase a replacement disk drive as its clear the laser is off kilter. In the mean time i would suggest not putting any other disks into the system until the issue has been resolved. Good luck!
Jan 25, 2009 | Microsoft Xbox 360 Console
My 360 won't read any kind of discs.
Exchage your X Box 360 for a new one.
Mar 06, 2008 | Microsoft Xbox 360 Console
My xbox 360 doesn't want to play any 360 games but it plays xbox games.
is this limited addition halo 3?
get a new one or find a place where you can get it fixed but there are not alot of places to get it fixed.im sorry im the barer of bad news.
Dec 04, 2007 | Microsoft Xbox 360 Console
Wont read disc
Have you tried multiple games? Perhaps the particular game in question is scratched, or is no longer being read by the XBOX 360.
Jul 28, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
