Question about Samsung Star GT-S5233 Cell Phone
How do u delete images and video from phone?
How do u delete video from phone? there is no option to delete
I want to delete photos etc ond my icloud to get more space without buying more storage?
The following guide will show you how to delete unwanted photos/videos on iCloud.
1. Tap on Setting > iCloud > Storage. Then tap on Manage Storage.
2. And then tap on This iPhone.
3. Under the Backup options, you will see Photo Library option, set the slider to OFF position.
4. Tap on Turn off & Delete to delete all photos and videos from iCloud.
After deleting existing photos and videos, you can either set the Photo Library back to ON position and start backing up new photos to iCloud or keep it OFF and use Photo Stream. You can store up to 1,000 images on Photo Stream for free and download them to your computer. These images will remain in Photo Stream for 30 days, after which they will be deleted.
How to Fix Not Enough Storage on iCloud for Your iPhone iPad
Mar 25, 2017 | Cell Phones
How do I delete photos in the gallery on Samsung Galaxy tab 4?
To delete a single image, summon the image on the screen and touch the Trash icon that appears in the upper-right corner. Choose the Confirm Delete command. The image is gone.
Deleting a video isn't as easy as removing an image: You have to long-press the video thumbnail in an album. The long-press activates multiple-selection mode. For removing a video, however, just touch the Trash icon that appears in the upper-right corner of the screen. Choose the Confirm Delete command, and the video is gone.
You can't undelete an image or a video you've deleted. There's no way to recover such an image using available tools on the Galaxy Tab.
You can apply the Delete command to an entire swath of items in the gallery at once. To do so, you must know the secret, found below:
  1. Open the album (pile) you want to mess with.
  2. Long-press an image to select it. Instantly, you activate image-selection mode.
  1. Continue touching images and videos to select them.Or you can choose the Select All command.
  2. Perform an action on the group of images or videos.
To deselect items, touch them again. To deselect everything, touch the Done command.
The type of commands you can use on a group of items in an album depends on the group. Some commands, such as Delete and Share, can be performed on any old group. Other commands, such as the image rotation commands, work only with pictures, not with videos.
Apr 26, 2016 | Samsung 7 Galaxy Tab 4 8GB White
Recovering deleted images on nokia e65
You can recover deleted images from Nokia with asoftech photo recovery program
http://www.asoftech.com/apr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
Aug 29, 2012 | Nokia e65 Cellular Phone
Cant delete photos does not give me the option to delete it
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense
Jul 24, 2012 | Huawei U8800-51 Impulse 4G AT&T Android...
How do I delete the photo stream albumn or images in it on iphone 3gs
Hi There
Its very simple to delete photo or photo stream to you iPhone 3gs
  1. Press the menu button and select photos.
  2. Select Camera Roll option and now hear you can get you all capture photo
  3. Now select which photo you want to delete, when you select the photo you saw option in you down right side like -(dustbin)
  4. Press that option now the pop up appear two option "Delete & Cancel" chose Delete option.
  5. Now you photo is delete if you want multiple select then you see in corner side "Multiple select option" select that one now you able to delete multiple photo in one time.
  6. Select which photos you want to delete.
See the video for halp
Video 1: Simple Delete
Video 2: Multiple Delete
Dec 22, 2011 | Apple iPhone 3GS Black (16 GB)
How do i delete all photos at once
In the playback menu select "Format" this will erase all images
Feb 28, 2011 | Vivitar ViviCam 8018 Digital Camera
How do i transfer my phone memory to the micro sd
You can store any multimedia files
on your phone’s memory in My stuff
so that you have easy access to all
of your pictures, sounds, videos and
games. You can also save your files to a
memory card. The advantage of using
a memory card is that you can free up
space on your phone’s memory.
My images
My images
contains a list of pictures
including default images pre-loaded
onto your phone, images downloaded
by you and images taken on your
phone’s camera.
My images options menu
The options available to you in My
images
depend on what type of
image you have selected. All of the
options will be available for pictures
you have taken on the phone’s
camera, but only the Use as, Sort
by Grid (List) view
and Memory
manager
options are available for
default images.
Send - Send the image to a friend.
Use as - Set the image to appear on
your phone at certain times.
Move - Move an image from the
phone memory to a memory card or
vice versa.
Copy - Copy an image from the phone
memory to a memory card or vice
versa.
Delete - Delete an image.
Mark/Unmark - Select multiple files.
Print - Print an image via PictBridge or
Bluetooth®.
File - Change the name or view the
information for the file.
Create new folder - Create a new
folder within the Pictures folder.
Slide show - Start a slide show.
Sort by - Sort images into a specified
order.
Grid view/ List view - View each
image in grid or list type.
Memory manager - View the memory
status.
Jul 26, 2009 | LG Secret ? KF750 Cellular Phone
Problems deleting pictures from "My Images".
hi austin... pls try to go to your file manager/ phone or memory card storage/ images/ options/ delete (1 by 1) or delete all... for the other option just plug in your phone to your computer if the phone is a plug in play type... then open the My images folder and delete the images you want to delete...thank you very much...
Jul 10, 2009 | Samsung SCH-u340 Cellular Phone
Cant delete images from "my album" on a sgh-t639 cell phone
Go to images, press the options (left) soft key to view the options:
Select Delete, you can delete either selected or many pictures that you have selected.
its the same, always left soft key (options) and then select delete from the list.
Full user manual at
http://downloadcenter.samsung.com/content/UM/200708/20070825034551421_tmobile_t639_ug.pdf
Let me know if you need anything else.
Thanks,
Ekse
Feb 24, 2009 | Samsung SGH-t639 Cellular Phone
How to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Jun 30, 2008 | Nokia 6630 Cellular Phone
Samsung Star GT-S5233 Cell Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
