Question about Edirol UA-25 External Sound System
Digital in out
I can´t connect my ada8000 in my edirol ua 25. I use cubase. when I open a track I can only choose the audio inputs but never the digital in. How to do it?
    Sergeant:
  • 357 Answers
The ada800 gives out 8 channels of ADAT, the edirol UA-25 are only stereo opticals and not compatible with the ADA8000 as it does not have any adat inputs or outputs.
Hope this helps
Posted on Jan 06, 2011
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
For some reason I cannot select my UA-25 as the ASIO Device in 'Audio System Setup' in VST5. VST 5 always seems to select 'ASIO Multimedia Driver' as the ASIO Device, which has a latency of 750ms. The...
I am using a laptop for my music creation and I am thinking about using an External Sound Card connected with a USB cable or getting an Sound Card. My integrated sound card has a little bit too much latency. Will I have just as much or more latency with the External Sound Card because it is connected with the USB cable or would I be better off with the Sound Card?
Thanks for vinu plz plz plz plz plz plz plz plz help me sir.
Mar 06, 2011 | Edirol UA-25 External Sound System
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Problem with guitar
1.make sure the guitar/mic switch is pointed to the guitar side. increase the guitar/mic level. increase the output level. 2.another thing you can do is check the "sound and audio devices" to see if everything is set to Edirol UA-4FX. If everything isnt, fix it so that it does. and remember to disable your computers stock sound card. Edirol UA-4FX is your new sound card from now on. 3. if thats not the case, try reinstalling the drivers. 4. If all of the above fail, you probably have a loose connection/ bad wiring in the guitar/mic 1/4" input. you can choose to open up the device and solder that yourself and possibly lose your warranty or have the entire unit replaced. Hope I helped! good luck!
Apr 30, 2007 | Edirol UA-4FX External Sound System
Edirol UA-25
A computer has line out and that means sound out from the computer to your speakers. A line out can also be connected to a recording device or a pair of speakers with an amp built in. Line in on a computer can be used to record audio from other equipment such as a Dj on his decks to record his set. It can also record audio from mp3 players etc. Line in can be used for mic's and also you can use mic in as well. To record any audio onto your computer use line in. Line out can also used for headphones and the mic will plug into mic in so you can talk online.
Oct 27, 2006 | Edirol Roland UA-25 External Sound System
"digital in" led flashes instead of burning constantly
Sorry, i'm new to the UA-25 as well, but from my understanding, if you are using a digital signal device and it is connected properly, that indicator should be steadily lit. IF you are NOT using a digital signal device and it's flashing, it's because you have the button pressed when you shouldn't have it pressed unless you want your sound to loop through the computer and come back to your headphones.
Sep 01, 2006 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
246 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
