Question about ViewSonic VG900 19" Flat Panel LCD Monitor
ViewSonic VG900 and Raritan Paragon KVM won't play.
The Viewsonic VG900 is not displaying on halg the positions on my network. The monitor powers up, displays for "a sec" and blanks. Is there a way to reset the resolution when you can't see the screen?
  • 149 Answers
Hi there, yes, go to safe mode first, then adjust the resolution to the lowest and restrat the unit. then you will boot up for a lower resolution and adjust it to your desire resolution. note that don't set it to higher resolution it will go blank again. ty
Posted on Feb 18, 2008
On my viewsonic moniter it is displayed as OSD LOCK
press in the three buttons on the monitor ( + , - , and menu) at the same time , connect the power cable, that will reset the monitor to the factory settings
if you see that is helpful please don't forget to vote me
best regards
Apr 23, 2011 | ViewSonic E70f 17" CRT Monitor
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Need tip size for viewsonic powere supply
insidecomputer_2070_4186448
Replacement Part Number: 1267-0526
Specs:
  • 40 Watt, 12 Volt AC Adapter
  • 4.8 mm Barrel Connector with Positive inside
  • Condition: New
  • Warranty: 12 Months
  • 100% OEM compatible, Guaranteed to meet or exceed OEM specifications
Compatible Models:
  • Hewlett Packard Jornada 680 Series
  • Hewlett Packard Jornada 720 Series
  • Hewlett Packard Jornada 728 Series
  • HP Jornada 680 Series
  • HP Jornada 720 Series
  • HP Jornada 728 Series
  • Planer LP150-BK
  • Viewsonic VG150
  • Viewsonic VG-150B Model
  • Viewsonic VG151
  • Viewsonic VP140
  • Viewsonic VP150M
Sep 07, 2009 | ViewSonic VG151 15" Flat Panel LCD Monitor
I have a Viewsonic VS11531 27.5 inch monitor I use a OmniView® PRO3 16-Port USB & PS/2 KVM Switch. The monitor has a res of 1900 x 1200 but when I hook it to the kvm switch the display will not...
In the link below, on page 9 of the PDF the maximum stated resolution of the KVM is Up to 1920x1440 @ 75Hz.
http://cache-www.belkin.com/support/dl/p75457_f1da116z_man.pdf
The monitor supports up to 1920x1200 @ 60Hz.
It sounds like there is an issue of synchronization between the monitor and KVM. This will force the monitor into a lower resolution to sync them. You may want to check with Belkin to see if there is a firmware update for the KVM. There may also be a driver issue with one(all) of the video cards on the system. I recommend updating the drivers on all affected machines with the monitor connected directly to the individual machines. Rather than using generic drivers, I would use the drivers downloaded from the manufacturer of video cards and from Viewsonic for the monitor.
Jun 28, 2009 | Belkin Computers & Internet
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
UMT242/USTIP2 not accepting remote clients, local only
I do not know this particular IP KVM but most IP KVM's use SIPPs that must be updated on the KVM when they are attached to the servers. Look for an option in the admin tools that say update SIPPs or update connection. You may also just have to double click on the list of connections to get it to update. This may have to be done at the console and not via remote.
Dec 18, 2008 | Raritan Paragon UMT242 (p2-umt242) 42-port...
Resolution problem of viewsonic VG2021m as the second monitor of thinkpad t61p
Go into the NVidia control panel, create a custom resolution (for the ViewSonic VG2021m, you want 1400x1050, 60Hz), and test it.  When the test asks you if it looks ok and you click "yes", it *still* is not activated-- it is simply added as one of the resolutions available for the monitor, and goes back to the same setting you had before... so it looks like it didn't work.  But then, if you go under "Change resolution", you'll see your new setting is available there.  Choose it, and you are good.
It's working for me, on my T61.
Dan
Jul 02, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Stuck screen resolution on monitor
it could have something to do witht he power setting's , go to properties / then screensaver , then click power options , u can turn sleep mode off there, and also change a few other things that may be causing this, your laptop may also have its own power setting , which is normaly in the task bar near the clock , high proformance , office, games, e.c.t , i assume when u plug the lcd in you have the power cord in the laptop connected, so i would just suggest my first option , and change the settings there , hope this helps
Nov 15, 2007 | ViewSonic VG900 19" Flat Panel LCD Monitor
VG910s not recognizing DVI input
Graphics card need setting to DVI out put Check your manual
May 16, 2007 | ViewSonic VG900 19" Flat Panel LCD Monitor
ViewSonic VG900 19" Flat Panel LCD Monitor Logo
81 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
