Question about Dymo LetraTAG Thermal Label Printer
NOT PRINTING when i try to print something on my letratag sr, the machine runs and tape feeds through but it does not print and the tape keeps feeding through until i switch off the machine ...
  • 1 more comment
  • Maurice Irvine
    Maurice Irvine Feb 21, 2008
    worked a treat, many thanks
  • gogogilbert May 06, 2008
    My dymo is not printing either. I have changed the batteries and tape.  Now what???
  • Anonymous Jun 08, 2008
    inserted a new reel, checked batteries. Dymo does not print!
Try changing the batteries. It worked for me.
Posted on Feb 19, 2008
  • srara Feb 03, 2011
    worked for me, many thanx
Will not feed in paper
TONY, UNPLUG PRINTER FOR 3 MINUTES REPLUG TRY PRINTING SOMETHING ALSO YOU MUST CLEAR ALL PRINTING JOBS THAT ARE IN THE MACHINE NOW,, CALL CUSTOMER SUPPORT FROM NUMBER IN YOUR MANUEL ,,TRY ALL ABOVE THANKS
Jan 24, 2016 | Office Equipment & Supplies
Sharp MX-2300N constantly sounds like it's feeding paper. It will feed paper just fine when it's actually printing something but it will still sound like it's printing something but nothing ever happ
The fuser will occasionally turn on and run to keep itself at 400 degrees. You can change the 'time to sleep' for both the fuser and overall copier through the Energy Saver admin level in the System Settings. If the fuser is running way too often, the thermistors may be insulated with a layer of toner which can be scraped off. If after a print or copy job, the machine still runs for 5 seconds or longer, you may have scrambled firmware needing a reflash.
Jun 03, 2014 | Sharp MX-2300N Color Copier
Dymo letratag blotchy print
Generally this is caused by something getting stuck on the print head. You can try a q-tip or a q-tip with pure rubbing alcohol on it and wipe of the print head.
Nov 06, 2013 | Office Equipment & Supplies
Why does my epson 1400 keep loading paper straight threw instead of printing?
I have had this problem several times. The culprit is the feed wheel which can get covered with paper dust and it loses it "bite". Epson sells cleaning sheets that are tacky and when run through the printer remove this "dust". I have also resorted to taking a piece of scotch tape and carefully sticking it to the rubber take-up wheel and then gently removing it to pull the paper dust off with the sticky tape. Another problem can be because of not setting the paper type correctly. Check to make sure that the paper type set for the printer is the same as the paper you are feeding.
Nov 09, 2011 | Epson Stylus 1400 InkJet Photo Printer
I am trying to load a new roll of labeling tape into the Dymo Organizer 1610. But the tape doesn't advance properly into the front part of the machine that does the printing.
Before inserting the tape into the feed mechanism, bend the last 1/8 inch of the tape upward at a slight angle. This will insure that the tape feeds properly. I just learned this by trial and error.
Aug 03, 2011 | Office Equipment & Supplies
When typing the print is faded
Dymo LetraTAGs are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the print starts to fade it's time to put new batteries in. When the batteries are running out the text fades first even when the motor is still feeding tape.
Jan 31, 2011 | Dymo LetraTAG Thermal Label Printer
I don't know if mine is thermal or not. But, I need ink and don't know where to replace it
Dymo Letratags are thermal printers, so they don't use ink - just batteries and LetraTAG tapes.
When the batteries are running out the text fades first even when the motor is still feeding tape, so change the batteries!
Jan 28, 2011 | Dymo LetraTAG Thermal Label Printer
Print Problem?
There are two small "hooks" that feed the tape through on the tape cartridge. Make sure the tape is fed through both hooks.
Jan 15, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Paper feed not working
remove the paper from the machine and look where it feeds in. There should be some rubber rollers, try cleaning them with a rag and some rubbing alcohol. If this doesn't work let me know. Also fan the paper before loading it. John
Jul 07, 2007 | Cannon i70 Printer
Dymo LetraTAG Thermal Label Printer Logo
221 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
