Question about Toshiba Satellite Pro A210-EZ2203X Notebook
Misc card stuck in slot, how do i get it out ?
Misc memory card stuck in sd slot, smaller card. how do i get it out ? toshiba a210
    Problem Solver:
  • 10 Answers
1. Shut Down The laptop
2. Remove the laptop Battery ( Close the Lid , turn the laptop Up side down, search for a battery Lock tab, move it to Unlock position, You can see a Lock/Unlock mark on the Laptop cover, this will eject the battery from the slot.
3. Get a tweezers carefully pullout the memory card from the card slot, utmost care should be taken not to damage the card slot contacts
4. After taking out the card put back the battery make sure that it is in the locked position
5. Start the computer , try out the system
6. Verify the memory Card reader functionality using a proper card as per the maker guidelines
Posted on Jan 31, 2010
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Memory card stuck in the SD slot
ohh
its a viurs.if is it nt detect virus gard
try to make externel memory card reder and dnt open.1st activate ur hiden fils and folders and go to memericad rigcht clik explor and del all hiden files specialy aoutorun.inf file del. and copy ur doc to pc then good for format ur memory card. tnx
Sep 13, 2009 | Canon PIXMA MP970 InkJet Printer
How do you put your sandisk microSDHC card with adapter in your camera
That depends on the camera. If the camera supports Sandisk Micro, then the SD card will fit into a slot. The slot is often located near to the battery.
You will just have to push card in and camera will automatically read card.
If camera does not read the card, ensure that the camera model can support SanDisk Micro, and that it will also support card size. Older cameras do not support big memory card (eg.4Gb)
Sep 05, 2009 | SanDisk 4GB microSDHC Memory Card
Sd card stuck in slot
you will have to remove the palm rest and then unplug the sd device look in the back of it and should be a small hole take a paperclip and push through the hole
Jul 27, 2009 | Toshiba Satellite L305-S5933 Notebook
Using multiple card slot
There will be a slot, the size of the SD memory card on the front edge or side of the laptop. The slot will be the same size as the slots in an USB memory card reader.
You can download a manual from the Toshiba WEB site.
You can download any/all the Windows XP or Vista device drivers and manual for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers and manual.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Apr 14, 2009 | Toshiba Satellite Pro L300 Notebook
Manual says virtually nothing about adding memory
If it's a newer laptop, generally the maximum is 4 Gigs. If it have an SD card slot, it will take SD cards. Most other cards can be made to work with an SD card slot if you buy an adapter. If it doesn't have a card slot, you can buy a multi-card reader for USB for under $20.
Feb 27, 2009 | Toshiba Satellite A105 Notebook
The m2 adapter i have does not fit my acer aspire laptop yet my laptop card reader says it reads m2 memory cards. is there a certain way of putting the card in to the memory card reader.
I think that with smaller memory cards like m2 and t-flash(micro SD) you would have to use their adapter(a card with a slot that normally converts it to SD) before you can slot it in.
Nov 06, 2008 | Computers & Internet
SD card slot -
The slot is for multiple card formats, usually SD/CF/xD/MMC etc...
Look at it closely you should see different contact points inside, your sd card should slip into one of the slots inside the larger slot.
BUT!!! Some user guides are printed for entire families of notebooks and mention all the available options for that type of notebook. Your laptop might not have come with an SD card slot at all even if it is mentioned in the book.
Jan 18, 2008 | Toshiba Satellite M35X-S161 Notebook
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
Toshiba Satellite Pro A210-EZ2203X Notebook Logo
210 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
