Is there any problem to use notebook pc without battery directly on AC adapter
  • 438 Answers
Good to go
Posted on Jan 31, 2010
Asus a3a laptop
Probably the AC Adapter is no good....Go to e-bay and purchase a new AC Adapter for that model # notebook. But if it shows charging then try first by taking out the battery and see if the AC adapter will run the computer without the battery in it (if so, then the adapter is good, the battery is actually bad, so replace the battery instead).
Good Luck.
Nov 29, 2013 | ASUS A3Ac Notebook
How to fix HP Pavilion dv9000
try it with the AC Adapter plugged in but without the battery. If the battery is too bad, it can prevent even the AC adapter from powering the laptop.
Mar 01, 2012 | HP Pavilion dv6200 Notebook
Can i run my portege 7100 without a battery?
Hi! Welcome to Fixya.
Yes, you can run your laptop without the battery. Just plug in your ac adapter.
Thank you for contacting Fixya. Bye for now.
Jul 20, 2011 | Toshiba Portege 7100 Notebook
My hp pavillion was no power without ac adapter
if the pc is not getting power without the ac adapter then most likely the battery is dead if it does not take a charge via the ac adapter then then the battery is no good or the ac adapter is busted
Apr 28, 2010 | HP Pavilion dv1000 Notebook
Battery has gone dead. When I plug the A/C cord in the light on the charger immediately goes out and won't charge battery.
try connecting ac adapter alone without the laptop, check if ac adapter light will stay green or blue.
try another power outlet using the ac adapter alone without the laptop check if the ac adapter light will stay as green or blue. if all fails replace ac adapter.
if ac adapter stays green or blue try connecting to the laptop without the batt, check if the ac adapter light will stay on, if yes then try connecting ac adapter to laptop with the batt plugin check if the light stays green. if not update the BIOS. if fails replace motherboard.
Oct 12, 2009 | Dell Latitude D610 Notebook
Travelmate dont switch on when i connect my adapter. even no led glows when the adapter connected. tried a new adapter still not working send me ur valuable suggestions to sheku1984@gmail.com
Remove your pc battery and try connecting directly to AC supply via your adapter. If you have a multimeter, you could measure your adapter's potential difference to be sure of the right voltage output ok. If nothing happened here, then you should open the pc's RAM compartment and remove the RAM(s). Re-install them properly and test one after another. You could also get a fully charged compatible battery and test alone, ie, without AC this time. If all these didn't work, then the culprit is the power unit. Good luck.
Jun 10, 2009 | Acer TravelMate 2300 Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Wont power-up with AC adapters, with or without Battery!
the notebook cannot be charged without the charger and further more if it is not working properly ,try get a new one and it will work.i also recommend that you show it to a technician .
Dec 24, 2008 | MSI MS-1022 Notebook
Can i run the laptop without a battery in it.plugged in with ac adaptor only
Yes, you can.
Laptops can run without battery with the AC, and it's fine, does not harm.
But however, I do not recommend you removing the battery and using the notebook with AC adapter only. The notebook is designed to be portable and with battery plugged in. In addition, using AC adapter only may cause the system to overheat since it is getting and using direct power from the power outlet.
Sometimes when you take out the battery your laptop doesn't work.
But that issue usually is related with some problem with the connectors of your motherboard.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | Dell Inspiron 2200 Notebook
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
