Question about Apple iPhone 3G Black Smartphone
My iphone 3g freezing and how can i get normal back
    President:
  • 239 Answers
Try a reset. Hold down the power key at the same time as the round home key until
phone powers down. Release buttons only when you see the apple logo,
then wait a min or two for phone to re-boot. You will not lose any data on the phone.
If this does not work, try an actual system reset. Sync iPhone to computer to back
up essential data ie contacts apps etc, then go to settings general and reset. Reset
all settings as a last resort. This will give you a fresh start and should sort out
the majority of any bugs the phone has. A resync with you computer will restore apps etc.
Hope this helps and if so please vote.
Thanks
Jim
Posted on Mar 13, 2010
I phone 3 freeze just showing apple
It sounds like you are stuck on boot. Hold down the power/lock button and home button together until the phone turns off and the apple logo appears again. Your phone should boot up normally.
Feb 13, 2013 | Apple iPhone 3G
Iphone just turned off!! Won't turn back on!! WHat do I do??
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 07, 2011 | Apple iPhone 3G
My iphone 3G just shut off on its own & it will not come back on when I try to trun it back on. Does anyone know more or less what I can do to fix that?
Is it completely charged? Plug it in and charge it overnight.
If it is charged, these steps may help:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Dec 16, 2010 | Apple iPhone 3G
My iphone 3g screen got freezed
If the problem is not hardware so it just require a reset.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Hope your problem is solved.
Dec 08, 2010 | Apple iPhone 3G
My iphone does not stay on 3g. How can i fix it? Its 90 percent of the time on edge...
i live in the UK and the reason why my iPhone 3GS does that is because some areas are not covered by a 3G network, so it uses normal internet also check in your settings that the 3G is on, as soon as i come in to a 3G area the 3G icon is back on
Apr 21, 2010 | Apple iPhone 3G
Hi can u help with my iphone 3g. it is stuck on invalid sim and emergency mode. how can i get this off? and is there a way to unlock a iphone 3g 3.1.3?
Here is what you have to do. Get a friend that is on the same carrier as the sim card that is in your phone.
Next take your sim card out and put a friends (same carrier) sim card in and restore it. When it is done it will still be in emergency mode. When it says invalid sim put your original one back in it and after about 30 seconds it will go back to normal.
This solution just fixed my iphone 3g so this should work.
Best of luck, Michael Proctor
Mar 30, 2010 | Apple iPhone 3G Black Smartphone
I just started having my screen of my Iphone (3G)
hit the screen with 3 fingers i know it sounds weird but should work
Mar 16, 2010 | Apple iPhone 3G
My iphone has a magnified screen which won't go back to normal size
tap with 3 fingers the screen and it should go back to normal ;)
Jan 05, 2010 | Apple iPhone 3G
I phone 3g went from normal screen to large screen how to change it back to normal
Double tap the screen with 3 fingers and it will unzoom. Then to switch the feature off,
go to settings, accessability and turn off zoom feature.
Thanks
Jim
Jan 01, 2010 | Apple iPhone 3G
Freezing iphone 3g
if yopu have too much files on the memory pls delete some,if it persist just flash in new memory and the hanging will be detected and it will be corrected.
Jul 17, 2009 | Apple iPhone 3G Black Smartphone
Apple iPhone 3G Black  Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
