Question about LG RU-42PX11 42 in. EDTV-Ready Plasma Television
WHT SHOULD I DO IF THERE IS A BLK LINE DOWN THE MIDDLE OF SCRFEEN AND WILL NOT GP AWAY
  • 30 Answers
THE PROBLEM IS ON THE COF BOARDS .CHECK THE CONECTORS AND THE 10R RESISTORS.
Posted on Jul 30, 2010
  • 438 Answers
Is this a vertical, or horizontal line ?
Posted on Jan 31, 2010
Where is the amp and how do i check it in 98 cadillac
Radio Amplifier
Left hand rear of the passenger compartment, behind the rear seat back.
Check the connections , check power an ground .
Connector Part Information
12110088
24 Way F Micro-Pack 100 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A1
PPL
1952
RH Front Tweeter Output -
A2
LT GRN
1852
RH Front Tweeter Output +
A3
BLK
1856
LH Front Tweeter Output +
A4
YEL
1956
LH Front Tweeter Output -
A5
DK BLU/WHT
346
Rear Shelf Subwoofer Coil 1 Output +
A6
LT GRN/BLK
1794
Rear Shelf Subwoofer Coil 1 Output -
A7
YEL
1860
Center I/P Midrange Output +
A8
LT BLU
1960
Center I/P Midrange Output -
A9
DK GRN
1795
Rear Shelf Subwoofer Coil 2 Output +
A10
LT BLU/BLK
315
Rear Shelf Subwoofer Coil 2 Output -
A11-A12
Not Used
B1
DK GRN/WHT
368
Right CD Changer Input
B2
BLK/WHT
372
CD Changer Common
B3
BRN/WHT
367
Left CD Changer Input
B4
LT GRN
1948
Right Audio Input -
B5
LT GRN/BLK
512
Right Audio Input +
B6
DK GRN
1947
Left Audio Input -
B7
TAN
511
Left Audio Input +
B8
DK BLU/WHT
653
Chime Input/Return
B9
PPL/WHT
652
Chime Input +
B10
Not Used
B11
PPL
1807
Class 2 Serial Data Line
B12
PPL
1807
Radio Amplifier (UX8) C3
showgif.do?image=35456
12064749
2 Way F Metri-Pack 480 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
BLK/WHT
651
Ground
B
RED
1242
Battery Positive Voltage (B+)
Check
Mar 22, 2016 | 1998 Cadillac Seville
Where can i get an 01 silhouette pcm pinout
PCM pinout diagrams
2001 silverado (Thanks Banker099)
Try this link for page below
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc1pcm2001.gif
Powertrain Control Module (PCM) C1 (BLU)
• PCM Connector C1 Assembly 12191489
• TPA (BLU) 12176408
• Connector Cover 12191108
Pin
Wire Color
Circuit No.
Function
BLK/WHT
451
Ground
LT GRN
1867
12 Volt Reference
PNK/BLK
1746
Fuel Injector 3 Control
LT GRN/BLK
1745
Fuel Injector 2 Control
5-10
Not Used
11
LT BLU
1876
Knock Sensor 2 Signal
12
DK BLU/WHT
1869
CKP Sensor Signal
13
ORN/BLK
463
Requested Torque Signal
14
ORN/BLK
1061
UART Serial Data [Secondary]
15
DRK BLU/WHT
774
UART Serial Data [Tertiary]
16
Not Used
17
DK BLU
1225
Transmission Fluid Pressure Switch Signal B
18
RED
1226
Transmission Fluid Pressure Switch Signal C
19
PNK
439
Ignition 1 Voltage
20
ORN
440
21
YEL
1868
Low Reference
22
Not Used
23
PPL
719
Low Reference
24
Not Used
25
TAN
1671
HO2S Low Signal [- Bank 2 Sensor 1]
25
TAN
413
HO2S Low Reference (Denso Sensors) HO2S Low Signal (Delphi Sensors)
26
TAN
1667
HO2S Low Signal [- Bank 2 Sensor 2]
26
TAN
413
27
Not Used
28
TAN/WHT
1669
HO2S Low Signal [- Bank 1 Sensor 2]
28
TAN
413
29
TAN/WHT
1653
HO2S Low Signal [- Bank 1 Sensor 1]
29
TAN
413
30
LT GRN
1478
Coolant Level Switch Signal
31
Not Used
32
BLK/WHT
771
Transmission Range Switch Signal A
33
PPL
420
TCC Brake Switch Signal
34
WHT
776
Transmission Range Switch Signal P
35
GRA
48
CPP Switch Signal
36
BLK
1744
Injector 1 Control
37
YEL/BLK
846
Injector 6 Control
38
PNK/WHT
1101
Damping Lift/Dive Signal
39
Not Used
40
BLK/WHT
451
Ground
41
BLK
407
Low Reference
41
GRA
720
Low Reference (w/o Delphi HO2S)
42
Not Used
43
RED/BLK
877
Fuel Injector 7 Control
44
LT BLU/BLK
844
Fuel Injector 4 Control
45
GRA
474
5 Volt Reference (FTP Sensor)
46
GRY
474
5 Volt Reference (TPS Sensor)
47
GRY
597
5 Volt Reference (MAP Sensor)
48
GRA
596
5 Volt Reference (EGR Sensor)
49 50
Not Used
51
DK BLU
496
KS [1] Signal
52
Not Used
53
BLK
470
Low Reference
54
BLK
452
Low Reference
55
BRN
1456
EGR Valve Position Signal
56
Not Used
57
ORN
440
58
DK GRN
1049
ECM/PCM/VCM Class 2 Serial Data
59
YEL
710
Class 2 Serial Data
60
ORN/BLK
469
Low Reference
61
PNK/BLK
632
Low Reference
62
Not Used
63
GRA
720
Low Reference
63
TAN
413
64
Not Used
65
PPL
1670
HO2S High Signal [- Bank 2 Sensor 2]
66
PPL
1666
HO2S High Signal [- Bank 2 Sensor 1]
67
Not Used
68
PPL/WHT
1668
HO2S High Signal [- Bank 1 Sensor 2]
69
PPL/WHT
1665
HO2S High Signal [- Bank 1 Sensor 1]
70
BRN
1174
Oil Level Switch Signal
71
Not Used
72
YEL
772
Transmission Range Switch Signal B
73
BRN/WHT
633
CMP Sensor Signal
74
YEL
410
ECT Sensor Signal
75
PNK
1020
Off/Run/Crank Voltage
76
BLK/WHT
845
Fuel Injector 5 Control
77
DK BLU/WHT
878
Fuel Injector 8 Control
78
Not Used
79
WHT
687
3-2 Shift Solenoid Valve Control
80
ORN/BLK
510
Low Reference
wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 799x247 and weights 17KB.connectorc2pcm2001.gif
May 23, 2014 | 2001 Oldsmobile Silhouette
1992 dodge dynasty radio diagram
Assuming the radio connects to the RS amplifier, the harness is as follows:
From fuse 13: PNK or BLK -> PNK/LT BLU -> PNK or BLK -> PNK/LT BLU -> radio (!)
From fuse 20: RED/WHT -> radio
From fuse 10: VIO -> amp
From radio: ORG and BLK/YEL to interior lights
From radio to amp: DK BLU/RED, BRN/RED, DK BLU/ORG, BRN/ LT BLU, VIO, DK GRN or DK GRN/WHT, DK BLU/WHT, BRN/YEL
From radio to pwr ant: DK RED/GRN
From RS amp to:
R. door: LT BLU/VIO and LT BLU/DK GRN
R. front: ORG/BLK and ORG/RED
R. rear: TAN/BLK, TAN/RED, TAN/DK GRN, and TAN/VIO
L. rear: WHT/DK GRN, WHT/VIO, WHT/BLK, WHT/RED
L. front: YEL/BLK and YEL/RED
L. door: LT GRN/DK GRN and LT GRN/VIO
Mar 17, 2017 | 1992 Dodge Dynasty
I am installing a 240v heater in my downstairs bathroom. The heater schematic has a single BLACK 240v live input wire and a WHITE 240v neutral output wire, plus a yellow/green stripe ground wire. I have...
you dont need all that wht is 120vt blk is 120vt thats your 240 their is no neatral on 240 volt ont a 120 volt circuit it sounds like it is wired correctly you may have a wire not getting good conection
Sep 18, 2010 | Heating & Cooling
Stereo wiring for a 91 honda accord
1. red/blk ---------lighting switch
2.wht/yel-----------to fuse No.24 (7.5A) under hood relay box
3. yel/red---------- to fuse No. 11 (10A) Dash fuse box
4.brn/blk ----------- (--) R front speaker
red/grn ----------(+)
6. brn/blk-------------(--) L front
blu/grn
7.brn/wht -----------(--) R. Rear speaker
red/ywl-------------(+)
8. gry/wht----------(--) L..Rear
blu/yel ----------(+)
9.BLK----------------- to the ground.
Apr 05, 2010 | 1991 Honda Accord
Need colour codes for stereo wiring for 2000 hyundai accent
ANT org/wht, LR spkr brn/blk, LF spk blu/blk, RF spk blk/wht, RR spk grn/blk, ILL blk/wht, ACC gry/wht, GRND blk, LF spk brn/wht, RF spk brn, RR spk grn/wht, ILL grn/wht, MEM power org/blk.
Dec 26, 2009 | 2000 Hyundai Accent
1993 ford thunderbird stereo installation guide/ wiring guide
bat.-lt.gr/ppl; grnd-blk; ign-yel/blk; lights-lt.blu/red & org/blk; grnd-blk/org; L.F.-org/lt.grn & lt.blu/wht; L.R.-pnk/lt.grn & tan/ylw; R.F.-wht/lt.grn & dk.grn/org; R.R.-pnk/lt.blu & brn/pnk
Nov 07, 2009 | 1993 Ford Thunderbird
Color wireing codes for DEH-P730 cd player
red - acc power
yel- battery power
blk - ground
blu - power antenna out
blu/wht - amp remote out
wht - left front +
wht/blk- left front -
gry- right front +
gry/wht- right front -
grn- left rear +
grn/wht- left rear -
prpl- right rear +
prpl/wht- right rear -
Aug 23, 2009 | iLO CA3000V CD Player
New vr-3 going into used 2004 Status. Current wiring has black connector and grey connector, also one blk/yellow stripe wire. Have wire colors written down, need to know what existing wires are -new radio...
According to www.the12volt.com The color codes for your vehicle are:
RADIO 12V CONSTANT |orange/black
RADIO SWITCH (ACC)|white/black
RADIO ILLUMINATE|green/white
LF SPEAKER|wht/blu - blk/blu
RF SPEAKER|wht/red - blk/red
LR SPEAKER|yel/blu - gry/blu
RR SPEAKER|yel/red - gry/red
Feb 24, 2009 | Clarion VRX935VD Car DVD Player
Wiring Diagram
Blk - Ground
Org - Light Dimmer
Red - Ignition Switch
Ylw - 12v+ (Battery)
Ylw/Blk - Cell Phone Mute
Wht & Wht/Blk - Left Front Speaker (LF)
Gry & Gry/Blk - Right Front Speaker (RF)
Grn & Grn/Blk - Left Rear Speaker (LR)
Purp & Purp/Blk - Right Rear Speaker (RR)
Jul 29, 2008 | Pioneer DEH-P3600 CD Player
Open Questions:
See all LG RU-42PX11 42 in. EDTV-Ready Plasma Television Questions
LG RU-42PX11 42 in. EDTV-Ready Plasma Television Logo
194 people viewed this question
Computer Repairing
Computer Repairing
