Question about Microsoft Xbox 360 Console
3 red lights
Please help .. i have got 3 red lights around my on/off button, the one that isn't lit is the top right many thanx sean
I am sorry clarky7781, but you have the infamous "red ring of death", sadly, the only way to fix this problem is to contact microsoft and tell them that you have the red ring of death and they will send you a box that you must send back to the company containing only your xbox console
Posted on Feb 18, 2008
1998 dodge Dakota Ok so I just got this truck and when I got it the abs light and brake light were on plus the speedo doesn't work sometimes I replaced the rear speed sense on the diff but the lights...
If the red brake light and the ABS light are both lit up on the dashboard, do NOT drive the vehicle. It indicates a major malfuntion with the brake system. The red light indicates low brake fluid or the parking brake engaged. The yellow ABS without the red light, indicates a problem the computer found and it disables the ABS system while still having conventional brakes. Since both are lit, it needs the brake system repaired. What you replaced on the rear diff was probably the rear ABS sensor. The vehicle speed sensor for the speedometer should be located on the rear of your transfer case if you have 4WD, or on the rear of the trans if you have 2WD.
Oct 11, 2012 | Cars & Trucks
Two questions: We have Panasonic KX-T7630 model How do I change/delete numbers to the personal speed dial numbers. Second, one of our phones has two buttons on the right lit up in Red like there are no...
If you mean the 10 number stored in 00-09, from the phone, pick up the handset (or press intercom) and dial *30 00-09 9 plus the number and # You'll hear a confirming tone. That stores the number. To dial, you press Autodial *00-09 and it dials the number.
What's under the buttons? Press PROG and the button and it will show what's there. Probably a digital station that isn't there. Press 2 and STORE and you'll clear the button.
Carl
Sep 28, 2011 | Panasonic KX-T7630 Corded Phone
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Theres a ring around the disc
the ring is from the console being moved when the system was on you can resurface the disk or theres a disk replacement program but with that ring it most likely will not work
Nov 29, 2010 | Microsoft Xbox 360 Console
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
Feb 18, 2009 | Dacor Millennia ETT304 Electric Cooktop
Can't select multiplayer
you need to hit the round X button the middle of both controllers and set which profile they will use.
Do it on controller 1 first then controller 2
Jan 07, 2009 | Microsoft Xbox 360 Console
When i turn on the xbox360 three red lights come on around the on button
if its three lights with the right upper quadrant not lit then you have the RROD..red ring of death..call microsoft and get the console replaced..i had three consoles replaced..before calling them do check if the cables are properly connected..questions which customer care asked me where: what is the light status on the power brick?green...is the power cord directly connected to the mains?yes..have you modified the system?no
i got mine within 4 days.eeb0cb0.jpg this is the image of the infamous RROD!hope it helps..
Oct 29, 2008 | Computers & Internet
Xbox red lights
You are unfortunately experiencing the red ring of death!
All of the information you need to know is located HERE.
Jan 21, 2008 | Microsoft Xbox 360 Console
How do I turn my oven on!
The oven pilot will need to be lit, On the bottom there is the oven safety valve, it has a red button on it, you must depress the button and hold it with the pilot lit for 60 seconds, when you release the button the pilot should stay lit and the oven will be ready for operation using the thermostat (knob). Please note: if the oven has set unused for some time you may need to hold the red button for a long time to bleed the air out of the lines. The pilots for the top burners are actually right beside each burner. You may need to turn these pilots on, they are controlled by small valves (small brass screws on the gas manifold where the gas valves and knobs are located, look between the knobs). These small screws/valves will open the gas flow to the pilots when turned counter clockwise. If you open these valves and the pilots still do not work, they will need to be replaced. Hope this helps
Nov 15, 2007 | Imperial IR-6-C Elite Gas Kitchen Range
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
