Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Magnavox 50MF231D/37 Plasma tv
My otherwise brand new set has a crack in the inner screen, no picture and only a loud buzzing sound coming from within. I’ve found parts dealers but most have little if any part descriptions. Is the inner screen replaceable and is the crack causing the buzzing sound? Any help would be appreciated very much.
Screen is cracked is there a replacement or can you find a replacement
  • Anonymous Apr 07, 2009
    My 4 month old Magnavox 42" (42MF237S/37) made a loud pop one night while we were watching it and a crack developed from the side of the screen. There had been no contact or impact to the TV. I called Magnavox Warranty and they have no record of my existance even though I registered the warranty immediately. Must be standard procedure.
    Problem Solver:
  • 10 Answers
I will buy the 50mf231d with the broken screen for 200 dollars ZACH-(301) 278 -7700. zlordzod@aol.com
Posted on Jan 13, 2009
    Novelist:
  • 84 Answers
You can have it repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
    Problem Solver:
I will buy the 50MF231D with the broken screen for $100
Bob 212-655-4415
bob@viacel.com
Posted on Apr 21, 2008
    President:
  • 1,284 Answers
The plasma panel in most cases exceeds the cost of replacing the TV. There is also the issue that they tend to use different versions and makes of panels in these sets. Some panels are made by Samsung and some are made by LG. I would start shopping for a replacement TV at this point.
Posted on Feb 21, 2008
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
Plasma inner screen cracked, and buzzing. Is it worth fixing the caps?
It sounds like this is an LCD tv - not a plasma.
chances are that if the screen was hit hard enough, at least one of the CCFL bulbs for the backlight broke too. This created a fault in the inverter circuit, cauing a shutdown after a second or two.
Nov 25, 2011 | Televison & Video
LG 42'' Plasma 42PC1DV loud pop,buzzing, no picture cracked screen
pdp panel cracks need replaced
Manufacturer LGE 42PC1DA Part Number EAJ42047868 Description 42 INCH_XGA PDP MODU
Manufacturer LGE 42PC1RV Part Number EAJ42007501 Description PDP,MODULE-VGA
Oct 04, 2009 | Televison & Video
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
this is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
Jul 12, 2009 | Philips Magnavox 27MS343S 27" TV
Red blinking light on a Magnavox Plasma TV
Here is the solution. For less that 100$ your Magnavox Plasma TV. Model # 50MF2310/37 will be running like a champ.
Issue:
Magnavox Plasma TV. Model # 50MF2310/37 screen has no picture. There is no sound, TV comes on and then after a few seconds clicks and screen remains blank.
Cause:
On the main power circuit board to Capacitors are prone to failure from over load. The caps are 3300uf 10v 105+c capacitors located to the left of the AC power input.
Service:
Magnavox will refer you to a service center. They will advise $$$ for an inspection. They will also want to charge upwards of 500$ to replace the entire board.
Solution:
1. Unplug your TV
2. Disconnect all connections from your TV
3. With assistance lay your TV on its face on a non-scratching service
4. Remove the back panel screws.
5. Lift back panel off
6. The central board is your main power board.
7. Remove all wire harnesses from the main board.
8. Remove all screws that are holding the main board in place.
9. Lift the main board out and carefully place it into a non electromagnetic pouch.
10. Take the board to a Circuit Board repair shop.
11. Have them replace the the above mentioned Caps.
12. Re-install the board in your TV.
NOTE: Replace the caps with 3300uf 16v 105+ high temp caps(preferrably Japanese caps)
This fix cost me 80$ and my time to search for other who had the same issue. Try searching for Magnavox Plasma TV. Model # 50MF2310/37 bad circuit board or Magnavox Plasma TV bad capacitors or Magnavox Plasma TV bad ciruit board.
Hope this all help, Magnavox is should take ownership for this problem and recall any tv's that have these caps in them. The worst part about this is that teh **** from the repair center that was paid 100$ to check the TV, stripped out the screw holes and damaged the case for the TV.
Portland Laptop Repair was awesome. They repaired the board and it looked like new. Check them out at http://www.laptopportland.com/
Jeff G
Portland, OR
Feb 10, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture and only buzzing sound coming from plasma with cracked screen
sounds like you may have a high voltage arc and / or leak . better to let a manufacturers qualified technician have a look at it this time . ask for an estimate after diagnosis and before repairs are made. factor age plus repair cost v/s a replacement tv . also in the area where i live most in shop repair estimates are cheap or even free . field repair estimates are definitely not . all tv parts can be replaced but, screen replacements can get expensive . barring neglect , abuse or a significant power surge you should not be having these problems on a tv so new. double check your warranty. most electronics come with 1 year on parts ,90 days on service. some warranty limitations are not allowed in certain states. also contact the manufacturer . in my expierence some of the better companies have honored an expired warranty partlialy and sometimes even fully on a relatively new product . after all they do have reputation to lose or keep . just be courteous and if your lucky they will be too. but if all else fails, i personaly prefer lcd flatscreen . oh , about the screen crack , clean and position your tv according to the owners manual . some of todays televison components are even more thermaly and chemicaly sensitive than ever . ie; window cleaner can whiten or even crack certain types plastics. finaly if you are not using a good surge protector now may be the time.
good luck
Feb 07, 2008 | Televison & Video
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
428 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
