Question about Sony RDR-VX530 DVD Recorder/VCR
Can this vx530 DVD/VCR record digital signals from antenna?I have a Sony Bravia TV that can display HD digital signals from a UHF/VHF antenna but how can I record the digital signals. I cannot use the DVD remote as there is no "decimal" (or dot) on the keyboard. Do I have to reroute the cables or antenna to get a "Line" input from the TV or Antenna? Thanks
  • 64 Answers
No,you can not unless you use a separated converter box.There is no way to get the digital signal out of the tv to be recorded.
Posted on Feb 14, 2010
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
Sep 27, 2011 | Sony Bravia KDL-32BX320
Dvdr3320v will this model record digital tv programs
This device has 2 composite AV, 1 S-Video, 1 Firewire, 1 RF video inputs. The RF input is a way for it to accept a signal from say a VCR's or Video Game's output on Ch 3 or 4.
Your device also can record via internal tuner.. The tuner can tune VHF:2-13, Cable:1-125 and UHF:14-69. Unfortunately, if you only have a UHF / VHF antenna on your house for TV (do not have cable TV, satellite TV, or the like) you're not going to be able to find anything due to the change from analog TV to digital TV. For this, you would need to purchase a digital TV converter box, and put the output of it into the the DVDR3320V.
I hope this helps and good luck. Please rate my reply. Thanks.
May 06, 2011 | Philips Televison & Video
I want to record a TV program and can't figure out how to do it. I have a Fisher HVD-805 model VCR player and a Sylvania HD TV. I have checked the plugs, cables etc and they are ok.
You must also connect antenna/cable to your VCR antenna/cable input, and then tune the desired channel at VCR and start recording, if your TV has video and audio outputs you can use them too, just connect them to line inputs of VCR, select them and start recording, this is more convenient when your VCR has only VHF/UHF but no cable channels tuner.
Feb 20, 2011 | Fisher Televison & Video
Convert normal tv to hd tv
HELLO
If the set you are trying to convert to HD is just your everyday standard VHF/UHF analogue TV - basically forget it! I am given to understand you cannot make your standard telly show HD pictures.
Sorry! That is, of course, anyone else knows different.
Sep 20, 2009 | Televison & Video
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
I am stucking with system Menu on progressive mode on Sony RDR-VX530
First of all, confirm connecting cables are correct n OK.
2nd, please confirm VCR is giving output signal or not.
Jul 20, 2008 | Sony RDR-VX530 DVD Recorder/VCR
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony RDR-VX530 DVD Recorder/VCR Logo
203 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
