Question about Toshiba Satellite A75-S211 Notebook
Shuts off soon after tryint to power up
Thi happens even with AC power plugged in.
    Genius:
  • 3,587 Answers
Hmmm..does it stay on long enough to check for screen saver mode? if not, use safe mode(F8) and then troubleshoot it.
by the way, you are my official 500th Fixya solution, and you are entitled to a FREE Shared Screen Service call(worth around 50 bucks) if you wish to have one.
send me a note at pn4pm@yahoo.com to proceed.
Posted on Feb 19, 2008
My laptops shut down when i put the adapter and doesn't get start up , but it's work normally with betray
Problem description:The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause:1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Reference: http://www.chargerbuy.com/blog/laptop-shuts-off-when-ac-adapter-plugged-in/
Sep 13, 2011 | Toshiba Satellite M205-S4806 Notebook
My toshiba laptop wouldn't work well when connected to power source but will function well am using the battery
Laptop shuts off when AC adapter plugged in
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard
Jun 20, 2011 | Toshiba Computers & Internet
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Hello. Today in the morning my laptop (Asus A8Jseries) was working alright. Then after 6 hours when i tried to turn it on, it didn't. I mean, it starts to work and Asus symbol comes alone, but then it just...
If it happens only when you move the adapter plug inside the power jack, it's likely that you have a problem with the power jack inside the laptop. The power jack has to be resoldered or replaced.
If it happens even without touching the adapter plug, the problem could be related to the faulty power adapter.
You can test the power adapter with a voltmeter and find out if the ouputed voltage is correct. If the voltage is not correct, replace the adapter.
http://www.chargerbuy.com/replacement-asus-a8-ac-adapter-19v-3-42a.html
But don't trust that even if the output votage matches specifications. It's possible that the power adapter doesnt' work correctly under load. Test your laptop with another known good adapter. If the laptop works fine with another adapter, your power adapter is defective and has to be replaced.
Mar 13, 2011 | ASUS A8J Laptop AC Power Adapter (4.3A...
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Toshiba Satellite A305 AC Adapter
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Power is erratic. Shuts off randomly.
it could be caused by a lot of things. isolate it first. since its randomly shutting down, try first in normal mode. does it heats up before it turns off, if yes its an overheating issue. you may need to replace fan or even motherboard of your pc. have you checked your battery? is it properly seated? or is the problem happening when your system is plugged with the ac adapter? try to check the power cable.
Apr 06, 2010 | Sony VAIO VGN-T350P/T Notebook
HP 530 Notebook will shut off by its self and when you restart it and will show you that windows was not shut down properly. Could it need a new battery?
The problem lies with the power supply system either in the power adopter or inside the laptop. When AC power is plugged in, the system shows that the battery is being charged (Yellow Light Indicator switches ON) but practically niether the battery is usually being charged nor the computer is being run by the AC power. Its a little bit of energy left in the battery that keeps running you computer for some time and as soon as the battery is discharged the note book shuts down by itself.
However, the Taskbar battery indicator gives the correct picture of battery charge and the charging process. Better rely on that.
Its a hardware problem pertaining to power supply and charging system and doesn't have to do any thing with Mother board, RAM, Hard disks or other hardware installed in the PC.
Do tell the above details to a repair workshop man to rectify the problem.... Best of Luch
Aug 18, 2009 | HP 530 Notebook
Toshiba Satellite A75-S211 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
