Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
I just purchased a Honeywell RTH2310 and cant get it to work. I have a gas furnace that has two wire R and White. I tried connecting to Red-Rh and W for white, with and without the jumper for Rh and Rc. Help!
  • 111 Answers
Red is 24volt power, white is load,I.E. relay,touch the red and wht wires together, the furnace should start, if it don't the problem is the heater, Rheat-Rcool you have a heat/ac thermostat, no ac forget Rc,try turning thermostat all the way up, dig up a multi-meter or powered light tester, touch Rh with one wire of tester,touch the other wire to different terminals until it lights,hook up your wires, you should have heat
Posted on Jan 31, 2010
I installed the RTH 230B thermostat, Theheat only works when set to the cool mode, I only have gas furnace(no ac unit). My old wires are Red, white, green and blue. What wires go where?
Hey jim Try....RH/RC jumper (connected with a small piece of wire)...RH/RC=RED...W=WHITE...G=GREEN blue=unused... should give heat only (in heat mode) no ac..tks
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
RTH2310, want to install on at two wire system, i understand R to red W to white but this thermostat has a wire connecting the Rh and Rc. and cannot move the screws how do i install my R wire
Hello LEAVE the jumper wire in and connect the RED to either RH or RC with the jumper.You need the screw to loosen to secure the wire.If its impossible maybe solder the wire on to make it reliable.W=WHITE
Dec 28, 2010 | Honeywell Programmable Thermostat Heater
Wiring problem?
Yes to everything!!
You have it figured out!!
Just make SURE that the blue unused wire cannot touch any of the other wires, it will wreck your transformer in a split second.!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Nov 25, 2009 | Honeywell Programmable Thermostat Heater
I bought a Honeywell programmable thermostat RTH2310 to replace my 10 year old Honeywell thermostat. My old thermostat is a 4 wire system but also has a jumper from Y to 1. New system does not tell me what...
It depends on the type of thermostat you have.
Do you have a 4 wire or 5 wire T'stat?
The red jumper wire was for a 5 wire t'stat with 1 transformer, the red jumper actually should have been from R to 1.
So you need to trace the wires back to the furnace and make sure they go to the locations identified below.
if you have a 4 wire t'stat then you don't need that jumper, if you have a 5 wire t'stat then you do need that jumper but it should go from Rh to Rc.
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
t'stat?
Nov 14, 2009 | Honeywell Programmable Thermostat Heater
My husband just installed the Honeywell RTH2310 thermostat. The fan turns on, but the furnace does not. What's our next step? (It's a natural gas furnace and he made sure that it is on correct h/e setting....
need to make sure there is a jumper between RC and RH if the red wire is connected to the RC terminal the heat wont work you will need a jumper wire to tie the RC and RC together with the red wire.
Oct 20, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
My problem is....On my new Honeywell RTH230B thermostat the color code is Rh, Rc, W,Y and G. My wire colors are red, orange, blue, white and black. I can obviously match up 4 of them but where the heck...
First you are using abnormal wire colors for a furnace. Second.... if you have an air conditioner hooked up to this furnace, you will need to install a jumper wire between rh & rc. I am assuming this is a natural gas furnace. Usually the red wire to R terminals. Usaully the white wire to the W terminal. Take the door off of the furnace. Find the thermostat wire connection in the furnace. What ever color wire is on the R terminal in the furnace should hook to the R terminal on the t/stat. Whatever color is on the W in the furnace goes on the W on the t/stat. Whatever color is on the G terminal in the furnace goes to G on the t/stat. And the Y in the furnace to the Y on the stat. and the G in the furnace to the G on the stat. Most applications use only the R, W, G, & Y ( always put the jumper wire between Rh & Rc)
Good Luck
Hvac Teacher
Mar 26, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
638 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
