Question about Kenmore Sewing Machines
Sewing machine does not stitch. Timing is out. How do I DIY repair timing on sewing machine. Imperial sewing machine similar to Kenmore. About 40 yr old electric sewing machine. Cannot seem to loosen screws enough to turn shaft to adjust timing. Hook does not pick up all stitches.
MakikiChris
  • 84 Answers
SOURCE: long stitch!!
Hi teza...I assume that you have decreased your stitch length selector resulting in no change, indicating that the internal stitch length mechanism is either insufficiently lubricated, or truly broken If not broken, you can work the mechanism free by removing your needle, selecting the maximum stitch length and any non-overlock stich pattern, ie. straight or zigzag, fully depress your foot pedal so it runs at maximum speed, and methodically press and release the Reverse button/lever. After a minute of this, hand crank your machine while observing the feed dogs, and changing your stitch length. If your stich length is set to 0, your should observe your feed dogs moving vertically up and down with no back/forward motion, however, increasing as you lengthen your stitch length. Repeat the previous high speed work out until you notice full strokes of your feed dog...good luck my friend
Posted on Aug 02, 2007
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
bargainbox
  • 1388 Answers
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
I'm **t sure what you mean by freehand stitching........do you get a good even stitch with zig zag, this is the most important first test ?
Ensure that all is clean and free of lint jams....**w for tension troubleshooting .......
This solution is for tension problems...if you can**t form any sort of stitch, the issue is quite different, so please let me k**w if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "k**tting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and **t to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do **t gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would **t recommend fiddling with bobbin tension without good reason, it may end up with missing small *****s and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (**t soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is ** lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension ***** in the middle of the metalwork....
4c76dc1.jpg ...the other ***** at one end is holding it all together, so beware....it is **t a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's ** trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension ***** very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it can**t be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....** case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (a**ther reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 09, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
TOP THREAD TENSION:
projects).
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
back properly.
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
OTHER ISSUES:
case....no case ? then make some sort of cover !
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
  • 1116 Answers
SOURCE: instructions manual for the handy stitch sewing machine
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Feb 21, 2010
How to fix timing on Kenmore 70 sewing machine
Try talking to the people at the link I attached. There are about 7 different adjustments to fix timing issues. Good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Feb 04, 2015 | Kenmore Sewing Machines
Singer 629 metal part at bottom won't spin around to pick up thread?
Most likely one or more of the gears that drive the hook have broken. If you are comfortable with taking the bottom cover off the machine you should be able to see the damaged parts. It is not a DIY repair because there is a timing gauge that is used in the repair and the timing needs to be exact or the machine will not make a stitch. Check with a sewing machine repair person you trust to look at it and give you an estimate for repair.
Sep 01, 2013 | Singer 3116 Simple
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Zig zag stitch not stitching
it possible that is could be the needle, is damaged, bent or blunt
it is possible that the timing has gone out on the machine, if it is the timing only a sewing machine repair shop will have the proper tool to fix the timing
Jan 18, 2012 | Brother Sewing Machines
I can thread my machine but when I try and catch the bottom thread (in the bobbin) it wont catch. Im not sure why
Check that the needle is in correctly, flat shank to the back. This is first thing to check as the hook rotates around and catches the thread from the back of the needle as the two come together to form the stitch. So if the needle is in wrong, the scarf at the back (scooped out area) won't be there and no stitch. Make sure needle is inserted fully up into the housing and that it is the correct system needle (most machines use the 130/705H system). Put in a new needle from the pack to make sure.
Is the bobbin in properly, rotating the right direction and under tension. So check needle, check bobbin, rethread everything and try again.
There is good general machine info on www.sewing.about.com which might help you too.
Less likely but it does happen, is the timing could be out, so the needle at the bottom of its movement and the hook swinging around it are out of sync. Timing can be knocked out if there has been a jam up, needle striking the sewing foot or something similar. If you suspect that this is what is going on, then probably time to take machine to a technician who can repair this.
Apr 10, 2011 | Kenmore Sewing Machines
I have a brother computerized sewing machine. It was working, now it will not pick up a stitch.
It is most likely that the timing is off. This is a repair that needs to be fixed by a repairman. It usually costs between $40 to $125 depending on the service charge plus the labor involved.
Aug 20, 2010 | Brother Sewing Machines
Machine does not hold any stitch except straight and seems to make unusual noises when i try to move towards other stitches(basting) etc It does not get real heavy usage,only occasional for home sewing....
Although you have not provided your machine details, very few manufacturers of anything give a 10 year warantee, and certainly exclude fair wear !?!?
Have you inserted a new needle and re-threadedplus cleaned out around the bobbin case and hook race just to be sure of basics first ?
When you have done that, just try a simple zig zag....if it now catches the stitch that is it, if not it may be timing.
Here is a LINK to details of how to adjust timing for Shuttle and Rotary, both front and top loading machines.
Aug 01, 2009 | Sewing Machines
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
SewTechWayne
SewTechWayne
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
