Question about Kenmore 22422 Top Load Washer
My Kenmore washer fills with water and then starts the wash cycle but it then stops and never switches to the rinse cycle so the water is never drained. How can I repair this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
Lid swich broken.
Posted on Jan 31, 2010
Star washing went get to rinse circle stop, press stop bottom and start bottom tries to start but not work
if you're saying it dies in the rinse cycle you could have a problem with your cold water not coming into the washer,the washer only uses cold water in rinse cycle,no cold water the washer won't run,try starting it just with cold water and see if it fills,if not bad water valve or problem with water in house valve or bad hose.
Apr 08, 2013 | Kenmore 24032\24036 Top Load Washer
Water will not stop filling for the wash or rinse cycles
OMG! Dude, what up cuz, down here in Mobile trying to solve my own washer problem!!! Tina Wow, talk about coincidence!!!
May 30, 2009 | Kenmore Washing Machines
Kenmore top load washer will not fill on rinse cycle
Hi, It does sound like the contacts in the water level switch are sticking. This switch is activated by presure not vaccum. You can try and bow into the hose leading to the level switch and see if it has any restriction but, it is more likely the level switch is going bad.
Do you have any problem on the initial starting of you wash cycle?
Let me know if this helps at all or I can answer any more questions.
Thanks
Vic
May 11, 2009 | Kenmore 24032\24036 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Mar 13, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
Feb 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
90 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
