Question about GE JVM1650 1000 Watts Microwave Oven
GE JVM1650WB008 Microwave. Daughter used left
GE JVM1650WB008 Microwave. Daughter used left over New Years paper plate with foil design to heat up food. Of course there was a small fire in the microwave before it shut down. Now unit does not turn on. Checked outlet -ok. Opened up unit and checked fuse -ok. What should I check next?
  • 254 Answers
Probably blew the magnetron or high voltage transformer DONT test either unless u discharge the capacitor possible shock risk that unit is still live even unplugged.... i wanna telll you these days that micros are disposable items because the parts are gonna cost more than just to buy a new one plus if any arching occured that same problem is gonna occur again if it did work so basicallly that miro is kapout... hope this helped
Posted on Jan 31, 2010
I got a GE 1000 Watt microwave free and after cleaning under the heating plate I noticed metal showing thru. Is it still safe to use?
No! it is not safe, the magnetron will arc, " burning it out " or the thermal fuse will kick in preventing damage.
Apr 28, 2012 | GE Microwave Ovens
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
I have a micro # JVM1650WB008 the the inside does not rotate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 0
=00
Sep 08, 2011 | GE JVM1650 1000 Watts Microwave Oven
My GE microwave (model# JNM1541DN1BB) is giving me a message; service may be needed keypad shortage. Question 1 how can I fix it myself? Question 2 why did my microwave go out and how can I keep it from...
HELLO.
The GE problem is with the magnetron being to close to the computer. If your microwave runs for a few seconds to minutes then resets with funny characters on the screen, you can follow these simple instructions to fix it.
needed things.
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
the way to keep it from happening again is to use the microwave with more caution.
Willing to help to help on other problems.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave #JVM1650WB008 is not heating.
heatman101
Mar 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Message given from my GE jvm1650wb008 Microwave!
WATTAGE AND CU.FT IS UP TO YOU. JUST MAKE SURE WHAT YOU GET FITS LIKE THE OLD ONE DID DIMENSIONS WISE. THE HIGHER THE WATTAGE THE FASTER THEY COOK AND HEAT FOOD UP.
Apr 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I believe the inline fuse is blown - where is it
my microwave will not heat food turn table is not moving and showning red smybols
Jan 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave will not heat any thing.
the plate has nothing to do with the microwave heating up the food
but the magnetron that heat the food is bad and will need replacing
I would ask a electronic shop how much they would charge to replace it , and if is not worth it to you then a new one would be a good call
Dec 01, 2008 | GE Microwave Ovens
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
GE JVM1650 1000 Watts Microwave Oven Logo
235 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
