Question about Samsung Blackjack SGH-I607 Smartphone
My phone is charged and goes on and off just like normal, but the phone won't turn on. as in the "phone is currently off" i hit "turn on phone" and nothing happens. HELP
  • spencer_blac Jan 31, 2010
    phone said it couldn't reset...
Go to start\settings\connections\wireless manager and turn on the phone. If it will not come on that way, do a hard reset after backing up your phone (contacts, calendar, and files) To do a hard reset, power up the phone and hold the up arrow on the joystick when powering up the phone. Agree to all of the questions and the screen will go into a DOS looking format. Your phone will power on every time after you do a hard reset.
Posted on Jan 31, 2010
  • 3,230 Answers
Well it seems like some firmware problem..... first of all you can try to hard reset your phone, When the phone is powered off press the Up Navigation key and the Power key at the same time, Storage and setting are wiped clean, eject the microSD memory card before doing a hard reset. or make a backup copy of your data......
Please post comments if further you have the same problem....
Good Luck!!
Thanks
Charge complete
i had that same exact problem, with my razr so i just went out and bought a new battery for like 15 dollars, and now it works like a charm thanks........
May 02, 2013 | Cell Phones
Iphone won't charge if on
Hello My Dear::::::\
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 12, 2013 | Apple iPhone 3GS Black (16 GB)
Phone is charged and won't turn on, also reset doesn't work
your battery is probably broken, try replacing it (ifixit.com), or let someone else fix it for you.
Dec 02, 2012 | Apple iPhone 4S
Safelink phone won't charge
my phone does not show that it is charging.i called safelink and told them about the phone she told me it as charging..
Jan 08, 2012 | LG 500g TracFone
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
W20i charged phone, took phone off charger, phone went dead and won't turn on. phone is six months old and had no problems
As you have got this problem and cell is only 6 months old. Pls get it replaced under warranty.
Do carry the invoice with date to the service center.
Alternatively also check the charger, as sometime the cell shows charging due to inserting the pin and a low current passes through but still charger is faulty. Try using some other charger and then go ahead.
Regads,
Richee
Take some time to rate me if it works well.
Jun 14, 2011 | Sony Ericsson Cell Phones
Phone turns on and off but wont start
try using ur phone while plugged in charging. if it works thn ur battery defective
Aug 05, 2009 | Nokia 6500 Classic Cellular Phone
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Samsung Blackjack SGH-I607 Smartphone Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
