Question about Samsung SF-5100 Plain Paper Laser Fax
ON/off button Is there an off / on button, I have plugged it in but cannot switch it on!
  • facos Feb 09, 2009
    I have the same problem. I have plugged it in but cannot switch it on!
  • dimitris591 Mar 06, 2009
    the machine denies to start up again after a general electricity black out
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,362 Answers
Tv has no display
plug it in and make sure you turn the switch on near the plug and then switch the tv on and press the standby button on the remote if you cant find the standby button then press all buttons on the tv and this should work
Jan 22, 2012 | Samsung Televison & Video
Its really hard to get trio v7000 to turn on.. what is the correct combination of keys. i have switch on and hold returnand play?
if it is plugged in to the power adapter just switch the power button on.
Or unplug it. make sure the power button is off. Wait a few seconds Then plug it back in.
If it is not plugged in to the power adapter. Switch the power button on, Then push the play pause button once.
Aug 18, 2011 | Mach Speed Trio V7000
How to reset canon mp258
Reset Canon MP258 Printer procedure:
1. Press power button / power switch
2. Plug cable power with holding power button
3. Press Reset button one, release power button and press reset button twice until control panel show "O".
4. Press "+" buttom, display changing from 0 to 1
5. Press Power Button again , Printer will be print 1 page
6. Open printer cover
7. Unplug power
8. Take out cartridge 810 and 811
9. Plug power
10 . Press power switch
11. Open scan cover
12. Insert cartridge 810, 811
Aug 02, 2011 | Canon Office Equipment & Supplies
How to reset mp258
7. Unplug power
9. Plug power
11. Open scan cover
Jun 14, 2011 | Canon Office Equipment & Supplies
I've just replaced the brake light switch on my Chevrolet S-10 pick-up. The brake lights stay on as if I have my foot on the brakes. How do I adjust the switch? Calvin
  • 1 Remove the negative terminal on the battery using a wrench. Look up under the dash and follow the brake pedal arm up to the switch. Pinch the tabs and pull the electrical plug out of the brake light switch.
  • 2 Remove the nut closest to the brake pedal arm using a socket. This allows the switch to be removed from the bracket.
  • 3 Install the new switch by adjusting the rear nut, closest to the electrical plug, back toward the plug until it is a few threads away from the plug. Remove the front nut closest to the button. Push the switch into the bracket with the button facing the brake pedal arm. Install the nut on the button side of the switch.
  • 4 Push the switch in until it contacts the arm and depresses the button. At this point, use your fingers to turn the front nut back until it contacts the bracket, keeping the switch from pushing back out of the bracket. Adjust the nut as necessary to assure the button is depressed against the brake pedal arm without moving the arm. Run the rear nut up to the bracket to lock the switch in place. Tighten the rear nut with a wrench.
  • 5 Install the electrical plug on the brake light switch. Install the negative terminal on the battery, and tighten with a wrench
  • Aug 30, 2010 | 1994 Chevrolet S-10
    How do i turn on my computer?
    There are many different models of MacBook, most have the power button on the right side of the palm rest up by the screen. If you are pushing this button and there is no response, try removing the battery, remove the ac adapter and press the power button for 15 seconds. Plug in the battery and power adapter and try the button again.
    Jun 10, 2010 | Apple MacBook Pro PC Notebook
    Its plug in..when you push the button its never run
    check the door pressure switch to see if its working. you can use a ohm meter for this test. you can also check by removing and inspecting the switch wires for lose fit. if the door pressure switch checks out ok, replace the start switch.
    May 29, 2009 | Whirlpool Dryers
    TV will not switch on from stand-by mode
    keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
    it should work.
    Mar 29, 2009 | Panasonic Televison & Video
    Model VSX-D511-S audio video multi-channel receiver not turning on at all do i need to get it serviced?
    First do the basic checking.Inspect the cord if not cut or break and secondly the outlet where you switch the plug if it's working or not if all the step is okey and yet no power,you better clean the switch with a contact cleaner,when cleaning take out the plug from the outlet,then proceed to cleaning press the button so dirt's come out,and toggle all switches or button so it will functionand try look for reset switch .Before you switch on the plug be sure you back the all original position of switches and button and you do not have power again....That's the time you go to service center.
    Jun 15, 2008 | Pioneer Audio Players & Recorders
    Samsung SF-5100 Plain Paper Laser Fax Logo
    99 people viewed this question
    Top Samsung Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    HEMANT GROVER
    Victorman
    Victorman
    Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
