Question about Samsung 225BW LCD Monitor
Need to replace all capacitors in my 225BW. Need
Need to replace all capacitors in my 225BW. Need a kit??
  • Samsung Master
  • 1,684 Answers
The 225BW monitor uses the same capacitor kit that the 214T monitor uses. You can order the repair kit at:
http://www.ccl-la.com/LCDrepair4.htm The kits run $12 including shipping. If you don't want to do the repair we do offer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 31, 2010
My SyncMaster 225BW 22 inch does unpredictable displays when my PC is first started up, or awakes from sleep mode. (display is shifted to the right, or brightness is stuck on very low, etc.). Before, I...
The brightness issues with this model are usually caused by a power supply that is starting to fail. There are parts called capacitors that start to fail, when this happens the power supply can not get to the correct voltage outputs that it needs to properly run the back light bulbs. This type of problem causes either the dim display that you have or a wavy display until the unit can stabilize the output voltage. It is repairable if you can do a little soldering. You will need to replace the 5 capacitors on the power supply board. Here is a link to a repair guide for that unit that shows what needs to be replaced.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
This is an easy fix, about 15 minutes once you have the parts.
Feb 04, 2011 | Samsung 225BW LCD Monitor
Tip
I have fixed 6 of these so far. All you have to do is replace capacitors C10...
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
on Sep 11, 2009 | Dell E173FP 17" LCD Monitor
Screen on samsung 225bw is black with on/off button blinking
Please check the video cable and try it with another PC first.
If it is monitor:
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 30, 2011 | Samsung 225BW Monitor
My monitor flashes on once then back to black when u hit the power button
Check the power supply caps for leaking/bulging tops first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Basic LCD monitor troubleshooting guide:
Nov 10, 2010 | Samsung 225BW Monitor
My samsung 225BW only shows for one second after i open my computer. What should i do? Also if i turn the moniter off and on it will show for one second and disappear. What should i do? Thanks
It probably has bad DC filter caps just like the rest of failed SAMSUNG monitor as shown in my albums, that will be the first thing to look for.
Nov 04, 2010 | Samsung 225BW Monitor
Why has my samsung 225 got a blue tint
Check all the pins on both ends of the cable and make sure they are seated properly, also try it with another PC to make sure it is not the video card paroblem.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Please post back what you find.
Sep 27, 2010 | Samsung 225BW Monitor
Monitor will not come on. Power light just flashes.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 13, 2010 | Samsung 225BW Monitor
Takes 5 to 10 minutes for the video to appear
Sounds like it could be a weak capacitor. Caps that are bad or weak will work after they warm up.
Dec 09, 2009 | Samsung 225BW LCD Monitor
Hi, i have Samsung SyncMaster 225BW monitor and while using Microsoft word it stop working. On off button blinking with blue light.. However when i plug/unplug the video cable nothing happens. Regards...
There r problem with your CPU not from Monitor might be any hardware failure at that moment.Pls restart the system after that if display is coming or not if display is not coming might be RAM chip is faulty replace it with goods one.If display still not coming then problem with your Motherboard.pls get it repair by vendor.
Nov 17, 2009 | Samsung SyncMaster 203B LCD Monitor
Monitor
Steve from Monitor Technology. You need to open the monitor and locate the inverter board.
Remove 3 screws,turn the board over and locate 2 caps,C110 and C111.Replace,820UF/35V
this will fix this problem.
thewizguy@comcast.net
May 03, 2008 | Samsung 225BW Monitor
Samsung 225BW LCD Monitor Logo
1,020 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
