VCR turns off within in seconds of being turned on
I have a Mitsubishi VHS cassette recorder that is probably 20 years old. Ysterday it suddenly began turning off within seconds of my pushing the power button. I check all the cords and plugs.
What do I do next?
  • 438 Answers
There is a fault in the unit, VCR`s are to cheep these days to Evan think of having your old one repaired, remember go green bring it to a electronic recycling depot
Posted on Jan 31, 2010
Light gradually getting darker and harder to make out
My understanding is that an LCD TV has a fluorescent tube for a backlight, an LED TV is LCD with an LED array for the backlight. Depending on what type TV, it's possible a technician could replace the fluorescent tube or whatever and get it working again. If it's a CRT TV, you might need a new PS or CRT.
Dec 13, 2013 | Panasonic Omnivision PV-7401 4 Head VHS...
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
Recording from a vhs cassette...
This dvd/vcr unit is having a problem with component failure. It is probably in the main power supply section, since the unit shuts down. This can happen in these products due to the qulaity of component use in the product runs. The components usually have 5% to 10% failure rate. Which is usually taken care of by the product warranty. Unfornately this is a common problem with big manufactuers and large production runs. You need to have the unit tested and serviced at a service center. The service center will have all the service information to repair you unit. The Magnavox Customer support telephone is 1-800-605-8453. Tell them the model number of you unit and about the problem with the unit shutting down during use. They will be able to tell how to your unit serviced. I hope this information helps you with your problem.
May 10, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Samsung DVD-VCR 357 combo has stopped recording VHS to DVD
Try blowing into CD tray with a can of air, works sometimes.
Jan 22, 2009 | Samsung DVD-VR357
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Mitsubishi HS-u59 video cassette recorder
You will have to choose a year that corresponds to the days of the week. In other words, the processor has not been designed to accomodate that far into the futured\...accordianman
Feb 11, 2008 | Mitsubishi HS-U775 S-VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
