Question about Compaq Computers & Internet
Compaq presario sr1950nx monitor wont turn on the usual green indicating its on is now orange...tried to inspect the video cable and video connectors for damage its seems fine.....the hard drive is working but the fan seems a little loud.
    President:
  • 2,992 Answers
It sounds to me like the computer is coming on but not booting. That is, there's power but it isn't actually starting up, so no video ever gets to the monitor. Until there is a video signal from the computer (you're calling it the hard drive), the power light on the monitor will stay orange. Also, the power supply fan in the computer spins at maximum speed until the computer starts up, and that's likely what you're hearing that sounds so loud.
Unplug the computer's power cable and remove the side panel. Make sure the memory modules are firmly seated in their sockets. This is a common cause for computers not booting. You can download the upgrading and servicing manual for this computer from HP's site here. This will give you all the instructions on how to open the case, where to find the memory and how to remove and reinstall it. Also be sure that all the internal cables are properly seated as well. Plug the computer back in and try restarting. Most of the time this will get you running again.
If the computer still doesn't start, the most likely causes are motherboard failure or a power supply problem. Unless you have access to parts to substitute for testing, your best bet is to have a computer service shop check it out for you and give an estimate for repair.
Good luck and thanks for using Fixya!
Posted on Feb 01, 2010
Compaq presario sr5030nx no video
compaq presario sr5030nx: This a Desktop? If so,Is the monitor plugged in, turned on, working, test with another machine, check the cabling from monitor to tower, unplug and inspect for bent pins. first. Now , when you say ,"compaq presario sr5030nx no video" and "black screen", do you mean your video player is not playing?
Nov 10, 2012 | Computers & Internet
My computer Compaq presario model SR1950NXhas the blue screen of death i guess is what it is called.How do I fix it?
usually a BSOD is related to a driver problem. Try booting in safe mode (pressing F8 after turning on) and go to device manager and see if you have any problems showing.
Sep 16, 2012 | HP Compaq Presario SR1950NX PC Desktop
Compaq sr1950nx unknown device after reinstalling win xp all video sound and network chipset and modem installed fine.
Go onto the Manufactures website and install all the drivers on there.
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3184153
Apr 25, 2011 | HP Compaq Presario SR1950NX PC Desktop
Power indicater light is orange instead of green and computer screen is black
This usually indicates no signal from the video card. If this happens at boot and no POST screen display is seen, try checking the connections between the monitor and the video card, there may be a loose cable. Inspect the ends of the cable for bent or damaged pins. Or try swapping the connection cable.
If this is happening after the post screen, then you have a video driver problem, which can be resolved by booting into safe mode, uninstalling your video card drivers and restarting into normal mode.
Hope this helps,
Gill
Jan 29, 2010 | Direct Source Distributing IBM G70 (Black)...
When i turn my computer on the big button which is usually green doesnt work. there is a smaller light which is also usually green just below the big one which starts green as i turn it on and then it goes...
Make sure your cables are all firmly connected. Also check the power strip or surge protector. If all is connected well and the pc will still not turn on it looks like the problem is the power supply unit, which can be replaced for around $20. I hope this works :).
Aug 16, 2009 | Compaq PRESARIO SR1475CL AMD Athlon 64...
Not transfering display but can't see whats going on.
Power up the monitor first then the laptop and the video will switch automatically to the monitor.
The other way, when the laptop is powered up press the Fn key + F4 key, This toggles the video output between the LCD and the external video connector.
Apr 13, 2009 | HP Compaq Presario V2000 Notebook
The sreen is black, and the monitor light is orange
This usually indicates an input problem. There are number of things to check:
Make sure the screen is plugged into a working output on the video card - if you can, test the video with a different screen.
Try a different cable; Swap for the same type of cable, or, if available, use a different output method(Such as HDMI).
If using an adapter on the cable, try using a different adapter.
Test the cable on a different display, if possible.
Ultimately, if the video card, cable, and connector are all working, or the display is still not, its likely a bad input board within the display - if you're savvy and have some time to kill, replacement boards cost between 20-70 bucks on ebay.
Feb 10, 2009 | NEC-Mitsubishi Nec Display Solutions...
Computer monitor won't tur on
check the connector to the pc from the monitor. it may have come loose. if you have a mouse, try moving it and see if the light on the monitor turns to green. it is possible the video has failed.
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Did you fix your Compaq 1220?
Any time you have a orange light . The monitor or video card can be at fault. First check the monitor. Turn it on and see if it goes from green to amber. Check all monitor cable connections. to make sure the all 15 pins are there . If monitor displays a message that check video signal most likely video card is the problem. Make sure you have the cable connection plugged in the back of the computer into the video card. Usually a picture of a monitor. Then afterwards turn the monitor on first then the computer. If you do the other way around then the video card most likely will not engage.
May 07, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
124 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
