Hello I have a television the picture is in a constant green/yellow picture, there is no way of adjusting the color, sometimes when I open the tv after a few hours after its been shut off the color is normal but then returns to the green/yellow picture. My tv is the Prima tv model Q2716. Thank You
May be its only a bad solder, please check crt socket
Posted on Jan 31, 2010
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Objects are doubled and colors are distorted
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
Red and Green and Yellow lines inthe Picture
Is this an LCD TV or and LCD Projection TV.
This sound like a convergence problem that sometimes can be adjusted in the user menu. Definintely can be adjusted in the Service Menu.
May 18, 2009 | Philips Televison & Video
Colors off. blue and yellow not lined up
try to set the convergance if you cant you can adjust the color tubes from inside the tv but have to be very careful to do this. There is actually only 3 colors in the tv red, blue green so I would say your blue and green need lined up
Sep 30, 2008 | Televison & Video
Picture keeps turning green or yellow
This could be the screen amp board or a picture tube shorting.
$$$ yes
Jul 11, 2008 | Sony KP-57WS520 57" Rear Projection...
How to adjust picture on projection tv
i have a 52" rca projection , and the screen looks like this ") (" on the sides can i do something to straiten it back out?
Aug 28, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Picture has a green shade
Sounds like your red picture tube is not emitting enough brightness to balance the colors. A temporary solution could be to slightly increase the screen voltage of the red CRT to give a good black and white picture when the color control is turned all the way down. If the set has not been serviced in the last 5 years or so, and you're not ready for a new HDTV set, it may be worthwhile to get a technican to look at it and clean the dust off the lenses and mirror and evaluate whether a picture tube rejuvination might work along with the gray scale tracking adjustments.
Mar 10, 2007 | Toshiba 51H84 51" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
