Question about Kowa Optics
Does not connect to the windup mech therefore cant reset and click the shutter.
  • 3,186 Answers
This camera question is posted in the TELESCOPE topic.
Posted on Jan 31, 2010
We have a 2008 Swan windup with rear l/h side windup mechanism failure. We are currently lifting by hand and placing a pole alongside the complete extension & taping it in place. Can this be fixed?
Anything can be fixed.....for a price. A dealer could do it but I'm sure it will be spendy, but if you know any men with mechanical aptitude, you might find parts in a wrecking yard and have them fix it for you.
Mar 29, 2016 | Cars & Trucks
"Error. Press shutter release button
hiit is not easy to tell what exact problem. It has quite of causes in your case. But I can only tell most common cause that it is sequence unit fail. It could also other like shutter fail, mirror box mech fail, motor fail, control pcb fail, and so on...etc...I recommended you bring to your local service place or Nikon service center which is helpful to you.
Jun 04, 2011 | Nikon D3100 Digital Camera
It has been a while since I have worn my watch. I have reset the time and warn it for a while but it has not started back. How long do I have to wear it before it will run on its own.
mcdevito75 here, If your watch is a quartz watch, have the battery changed, if your watch is a windup watch that hasn"t started due to you not wearing it in a while, you can try to KICK START it in a way. Take the watch off and as if to set the time of day, pull the stem out and move the hads back and forth, say from 3 to 9 then back again, sometimes this motion of the hands moveing and the stem being pulled in and out can KICK START a windup watch. If this does not help, see the repair service here at fixya, bottom of the page click on repair service directory then watches. I am Mike D I am in the directory and can help out if needed.
Jul 25, 2010 | Michele CSX Diamond watch
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
After develop the pictures i found that some images are completely blank and the images are cut into half. Half develop and half not. what the cause of it?? thanks
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
Oct 08, 2009 | Canon EOS 5000 35mm Film Camera
Periodic power loss to ignition on 2000 Tundra.
Check the connections on the battery,It sounds like one or both may be loose.
Jun 02, 2009 | 2000 Toyota Tundra
The arm on my 1015 Werlitzer will not reset itself.
THE GEARS OR OUT OF LUBRICATION.
LUBRICATE WITH WHITE LUBE GREACE.
THEN TURN THE KNOB ON THE GRIPER ARM
TO RAISE, AND LOWER THE ARM. THE ARM IS STUCK.
DOCTOR FIX IT
IN-HOME JUKEBOX REPAIR
6362273300
BALLWIN MO.
Feb 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
Film advance
It usually is the shutter not firing therefore jamming the advance. Try www.flcamerarepair.com They do not charge for ests.
Jun 28, 2008 | Minolta Maxxum 300si 35mm SLR Camera
JVC Ch-X11
Make sure the cds are the right way up.
Try listening to the cd mech to determine if the cds are being loaded.
If the mech is going through the motions then the problem could be the lens is dirty, the laser has failed or the spin motor is faulty.
if there is no sound of the cds being loaded, it could be a power supply problem. Try a reset or just unplug the changer then re connect it.
John
Oct 16, 2007 | JVC CH-X1100RF 12-Disc CD Changer
Optics Logo
104 people viewed this question
Top Kowa Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Kowa Optic Expert? Answer questions, earn points and help others
