Question about Dell 4100MP Multimedia Projector
The message on the projector says ''fan failure''
  • 144 Answers
You have a problem with your fan/s, it will not start so it has either got a fault with it or the sencor has been knocked.
Posted on Jan 31, 2010
2 Suggested Answers
  • 15351 Answers
SOURCE: I get the message of fan failure in my optoma hd
first vac and clean vents for proper air flow if still coding with unit unplugged remove cover and check fan for blockage if good and still fan code test fan, if bad fan is replaceable most electronics or some computer stores should have it if u want to diy can use serial&model number of projector or numbers on the fan
Posted on May 18, 2010
My Acer X110 DLP Projector shuts down with a message "fan failure"
clean the fan if you have blower do air service. otherwise open it and clean the fan.
if fan totally not working then need fan replacement.
Apr 18, 2013 | Acer X110 Projector Svga Dlp 3D, Eco,...
I am getting a message on projector that fan stopped. what does that mean?
hi,
ur projectors lamp cooling fan have some problem. if the fan stopped the lamp will get over heated, that's why cooling fan is must. its a warning message if not it will create some problem to ur projector's lamp. u should use the projector only after solving the fan problem.
ok
Dec 17, 2010 | InFocus Office Equipment & Supplies
I get the message of fan failure in my optoma hd 80 home theater projector, is it fixable, needs a replacement fan, etc.?
May 18, 2010 | Optoma HD80 Projector
Message reads failure to srike lamp. bulb is less
that ones are total ****... seems like lamp is broken .. my advice would be get a new projector(not LP70) other that get a new lamp...
Mar 02, 2010 | InFocus LP70+ Multimedia Projector
I just replaced a power supply, it has one fan instead of 2. Works great but now I get an error message saying it can't find the fan (which I'm no longer using), how do I get rid of the message?
replace the fan. it needs all the fans the projector was designed with to properly cool it down. without all the fans, the lamp will overheat and cause premature lamp and projector failure. the fan has 3 wires- ground, power and sensor. if the fan spins too slow or not at all, the projector will shut down to prevent damage.
so, replace the fan.
Jun 30, 2009 | InFocus LP70+ Multimedia Projector
Optoma HD70 "Fan Failure" message, PLEASE HELP!
Simply just navigate the meny system until you find the high altitude option, the switch it on
The projector should work fine now.
If you experience problems with your Optoma projector after onle 3 mnths, assuming it was new when you bought it you still have 9 months of warranty you know, you shouldnt hesitate to bother the seller
Apr 02, 2009 | Optoma HD70 DLP Projector
Fan failure erratic
Lubeor replace the fan.If you cannot do this, take it to a repair shop.The fan is monitored because without it the projector will melt down a la china syndrome
Mar 24, 2009 | Optoma EP730 Multimedia Projector
We have an optoma ep739. when you turn the lamp on, a message 'fan failure' comes on. the fan is running at what appears to be a slow speed. the red temp light goes on and then the lamp turn off.
Hi there
Try cleaning out the fan by blowing it out with a compressor. Most of the time this is only caused by dust.
If the problem stil occurs , try spraying it on the inside with a lubricant.
If the problem stil occurs you will have to replace the faulty fan.
Very cheap to have replaced.
Apr 02, 2008 | Optoma EzPro 739 Multimedia Projector
LVP-X3004 Mitsubishi Projector
Problem could be a fan problem or heat sensor or power ballast. Or at a board level a circuit board component failure - IC, capacitor etc Best to have it serviced by an authorised repair shop for Mitsubishi projectors. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Jun 22, 2007 | Mitsubishi LVP-X30 Multimedia Projector
Dell 4100MP Multimedia Projector Logo
189 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
