Question about HP Deskjet F4100 All-In-One InkJet Printer
I installed the hp58 photo ink for my printer HP desktop. i placed it into the black slot like the picture shows, but all my photos printed out blank how do i correct this?
  • thecoolcindy Jan 31, 2010
    Yeah. I turned off the print and back on and it just printed a test page fine using the photo ink.
    I am trying to use the program provided by the printer photosmart essentials maybe this is the problem. if so what should i print with?
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    Did you remove the film strip off the cartridge?
    Guru:
  • 731 Answers
I believe that the program has difficulties in communicating to the device, i advice you to follow the below steps to correct this issue.
1. Click start ->Run.
2. In the Run window, type "devmgmt.msc" (without quotes), click OK.
3. Device Manager Window will pop out, in this screen at the bottom you will see "Universal Serial Bus Controllers"
4. Click on the(+) sign next to "Universal Serial Bus Controllers" and look for "USB Composite Device".
5. Right click on "USB Composite Device" and select Uninstall.
6. After the the device is uninstalled, disconnect the USB cable from the back of the computer.
7. Restart the computer, after the system is booted plugin the USB cable.
8. You may need to wait for sometime for the device installation to get complete.
9 . Then try to print a word document.
Thanks & Regards,
Rizwan
Posted on Jan 31, 2010
How to change the ink cartridge
Follow these instructions when you need to replace print cartridges.
• Everyday printing: Use a black cartridge along with a tri-color cartridge.
• Color photos: Use a photo cartridge along with a tri-color cartridge.
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge towards you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,
store the black print cartridge in the print cartridge protector or an airtight plastic
container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do
not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad
electrical connections.
8. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into
the empty cartridge slot. Make sure you push the print cartridge in firmly until it snaps
into place.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Jun 30, 2011 | HP PhotoSmart C4385 All-in-One Printer
I have never used the Photo ink Cartridge #58. It intal pic shows putting it where the black one goes-does this mean I would use the color and the photo one at the same time instead of the black one?
Yes correct.The photo cartridge has to be inserted, where you install black cartridge.The photo cartridge gives finishing touch to the photos which you print.The actual photo comes from the color cartridge only, but for lightness and darkness, the color(ink) from photo cartridge gets used.In photo cartridge there are three color ink, that are light pink, light blue and grayish black.In color cartridge there are three color ink, that are pink(magenta), yellow and cyan( blue).------------- This are the details.Thank you for using fixya.
Mar 24, 2011 | HP Deskjet F340 All-In-One Printer
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How to load the ink cartridge
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do i remove the ink cartridge ?
Turn on the unit, then open the print-carriage access door by lifting
the handle until the door locks into place.
The print carriage moves to the center of the unit.
You may want to use a photo print cartridge for
superior print quality when printing photos. With the
color and photo print cartridges installed, you have
a six-ink system. See how to print the best quality
photos on page 22 for more information.
52 maintain your hp psc
hp psc 2200 series
2 After the carriage stops moving, lift the latch to release the print
cartridge, then pull it toward you out of its slot.
3 If you are removing the black print cartridge in order to install the
photo print cartridge, store it in the print cartridge protector.
4 Remove the new print cartridge from its packaging and, being careful
to touch only the black plastic, gently remove the plastic tape.
Caution! Do not touch the copper contacts or ink nozzles.
5 Push the new print cartridge into the appropriate slot until it clicks into
place.
The tri-color print cartridge goes on the left and the black or photo
print cartridge goes on the right.
manual:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c01176633/c01176633.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | HP PSC 2210 All-In-One InkJet Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    How do I install ink cartridge for hp photosmart C4280
    slot on the left.
    5. Pull the print cartridge toward you out of its slot.
    6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
    8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
    part of the print cartridge forward until it clicks into the socket.
    Work with print cartridges 69
    Maintain the HP All-in-One
    9. Close the print cartridge door.
    If you installed a new print cartridge, the HP All-in-One prints a print cartridge
    alignment page.
    10. When prompted, ensure plain white paper is loaded in the input tray, then press the
    button next to OK.
    NOTE: If you have colored paper loaded in the input tray when you align the print
    cartridges, the alignment will fail. Load unused plain white paper into the input
    tray, and then try the alignment again.
    11. Place the page print side down on the scanner glass and then press the button next
    to OK to scan the page.
    When the On
    Please Don't forget to rate this solution. Thanks.
    Feb 17, 2009 | HP Photosmart C4280 Aio Printer
    HP PSC 1300 All in one Printer
    1. Turn on the HP PSC and lower the print-carriage access door.
      The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
    2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
        NOTE: The black cartridge is on the right side of the print carriage.
      Figure 2: Removing the print cartridge
        NOTE: It is normal to see ink buildup in the print cartridge slots.
    3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
        CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
      Figure 3: Removing the plastic tape
    4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
        CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
      Figure 4: Inserting the print cartridge
    5. Close the print-carriage access door.
    Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
    The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
    With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
    Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
    c00034854.jpg 1 - Inserting the print cartridge
    2 - Removing the print cartridge
    Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
    1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
    2. Press Scan .
      The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
    Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
    How do I install an ink cartridge? HP photosmart c5280 All in one
    To replace the print cartridges Perform the following steps to replace the print cartridges:
    1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. The HP All-in-One can get damaged if the print cartridges are not docked safely when trying to remove them.
    2. Open the print cartridge door. The print carriage moves to the far right side of the HP All-in-One. Figure 1: Opening the print cartridge door c00956268.gif
    3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. Figure 2: Removing the print cartridge from the slot c00956269.gif 1 - Tri-color print cartridge slot 2 - Black and photo print cartridges slot
    4. Pull the print cartridge toward you out of its slot.
      NOTE: Remove the black print cartridge to install the photo or gray photo print cartridge, and store the black print cartridge in the print cartridge protector or an airtight plastic container.
    5. Remove the new print cartridge from its packaging, and carefully remove the black plastic tape by using the pink pull tab Figure 3: Removing the new print cartridge from its packaging c00956270.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the print cartridges. Doing so can result in clogs, ink failure, and bad electrical connections. Figure 4: Do not touch the copper-colored contacts c00956271.gif
    6. Hold the print cartridge with the HP logo on top, and insert the new print cartridge into the empty cartridge slot. Make sure to push the print cartridge firmly until it snaps into place. If installing the tri-color print cartridge, slide it into the left slot. If installing a black, photo, or gray photo print cartridge, slide it into the right slot. Figure 5: Installing the print cartridge c00956272.gif
    7. Close the print cartridge door. Figure 6: Closing the print cartridge door. c00956273.gif HP All-in-One prints a print cartridge alignment page if a new print cartridge is installed.
    8. When prompted, ensure plain white paper is loaded in the input tray, and then press OK .
    9. The HP All-in-One prints a test page, aligns the print head, and calibrates the printer. Recycle or discard the page. A success or failure message appears.
      NOTE: If colored paper is loaded in the input tray when aligning the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support at www.hp.com/support If prompted, choose your country/region, and then click Contact HP technical support.
    10. Press OK to continue.
    May 15, 2008 | HP Office Equipment & Supplies
    Printing photos
    its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
    Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
    HP Deskjet F4100 All-In-One InkJet Printer Logo
    83 people viewed this question
    Seeker5211
    Seeker5211
