Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
I think i might have removed the cd-rw/dvd-rom burner from the control panel add and remove programe how can i get it to wrork again?
  • 394 Answers
You may have removed it from the control panel add/remove but it May be saved in the Recycle Bin. Open Recycle bin and look for the Program you removed and click Restore.
If you are using a Windows Operating System you can use the System Restore Feature. Restore to a earlier point. You can restore the computer to a point before the accidental removal. Click start.Click All Programs. Point accessories-- system tools
System Restore.Click Now you are in it. Restore to an earlier time.
A bit scary but a Very good thing to learn. Best Wishes
Posted on Feb 01, 2010
  • Acer Master
  • 2,517 Answers
If you want to take out your cd/dvd rom then no need to romeve any thing frm control panel. Just turn off your system and remove.
When you put back your system automaticaly detect your cd/dvd rom.
Thanks & waiting for your feedback
Posted on Jan 31, 2010
MY dvd writer not detect dvd. but detect cd. this is dvd problem.
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope it helps
Aug 30, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
CD R/RW and DVD R/RW won't burn
ok lets try a system restore to see if it was indeed something you did..
ON WINDOWS XP
click start, all programs, axcessoires, system tools , system restore.. Now follow the onscreen instructions and restore your computer to a previous date, one in which the burners wrorked..
On VISTA
CLICK START, Accessories , System tools , System Restore
Follor thw on screen instructions and and restore your computer to a previous date, one in which they did work.
Let me know how that goes.
Jan 20, 2008 | Sony DRU 530A DVD±RW Burner
I'm trying to burn a dvd with power2go and when i did it only came up as a mp3 so i can only hear it on the dvd player and not see it... what am i doing wrong?
you will need a program like Any Dvd which removes all the protections on the dvd before it can be burnt these are on the dvd to protect against piracy or
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
Apr 11, 2011 | Sony DRU-820A DVD RW Dual Layer Burner
My dvd rom only can read cd. dvd cant read. please help me...
hope this helps
Feb 16, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Dvd rw is not working. I cannot burn a cd or dvd, What can i do?
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Feb 05, 2011 | Dell (7W036) DVD+RW Burner
My CD-ROM is not recognising any CD/DVD And CD-ROM icon is also missing in my computer menu
Go to Control Panel/System/Hardware, delete the CD-ROM, and reboot so the system can find it again. If it doesn't come back after the reboot, then try physically detaching and reattaching the drive (with the power off, of course).
Oct 25, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
ACER 9410CD/DVD-ROM driver not found.
I am assuming you are using XP,
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
Aug 14, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
LG powerDVD installer
drive mite be it is bad or need to check systems files and see if the power has beed turned off sometimes this happenes (go to add and remove hardware in control panel and add cdrw make sure you have the correct name of the cdrw you are installing .
if this doesn't work get bacvk with me lala linda
May 15, 2008 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Gateway laptop dvd drive promblem
ok you need to completely remove the cdrw from the pc remove all software (turn your pc off ) reboot it with out it ,then reboot it with the cdrw in it and go to add and remove hardware in your control panel and add driver when it asks and i think it will work correctally lala linda
Feb 01, 2008 | LG GWA-4082N DVD RW Dual Layer Burner
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
150 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
