Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwash why my kenmore dishwash's cover (put detergent) can not open when dishwash is working?
  • 254 Answers
Sometimes those dispensers become defective,, make sure nothin is obstructing it from opening possibly dishes or rack attachments,, if not then u will need to order a new dispenseer assembly if this is a whirlpool built kemore,,,( kenmore just puts there name on aplliances, they dont build them) just to let u know if u didnt know already...
deteremine your model number go to sears online check out there parts and service page and research parts by puttin in your model number and determine the part number for your model ,,,, i believe they vary from 20 to 60 dollars ,, this is somethin you could do just have to get part and seperate the panles by removing the screws all around the inside door.. hope this helps
Posted on Jan 31, 2010
Detergent door on my Kenmore Elite Stainless Steel dishwasher will not open during the wash cycle.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 23, 2011 | Kenmore Dishwashers
My kenmore 1694192 detergent cup does not open during cleaning cycle?
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Sep 06, 2010 | Kenmore 24 in. 16994 Built-in Dishwasher
Small door where soap goes does not open during cycle.
Most detergent cups are spring loaded and released by either a mechanical trip or by a bi-metal strip latch. If your model is a simple dial timer type, look for a mechanical linkage between the timer and detergent cover. If it is a touch panel control, look for the other type. The bi-metal strip type has a heating wire wraped around it that can open electrically or burn out physically.
Mechanical types can be checked by rotating the timer knob 360 degrees while watching the detergent cover linkage. Electrical types require use of an ohm meter to check the resistance of the heating element on the bi-metal strip.
If you are using powder type detergent, make sure it is not caked when added to the cup or it can jam the rotating type covers.
Feb 15, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
It is leaving soapy taste on dishes
you are using way to much detergent. and it is probably a stainless steel dishwasher. you should run a cup of vinegar on the top rack face up with nothing else in the dishwasher and no more detergent. run the vinegar in the dishwasher 3 times and then only cover the detergent tray a third of the way when washing the dishes.. do not put any detergent in the prewash slot.
Dec 24, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
My detergent cover broke
yes u can run it just like that or vist sears.com for parts u need Here to Help Shaun
Nov 18, 2008 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Maytag model mdbtt70aww. After the end cycle. open the door and found detergent tab on the bottom and the main wash cover is opened. Maytag diswasher model MDBTT70AWW. Put dishes and so...
Check both arms are spinning freely when you have the machine loaded up normally.
If thats ok you could try powder instead of tabs if they are not disolving correctly
Apr 05, 2017 | Dishwashers
The cover of detergent dispenser does not open..
switch back to using powdered soap, sometimes what happens is hte tablets your using are actually to big for the dispensor door and too much pressure is put againt the actual door so when its triggered to open there too much resistance nad cannot open, sounds silly bu have actually sen it in action. and liquid detergent tends to clog or gunk up hte door spring assy, powdershte best detergent to use for d/w's
Mar 20, 2008 | Kenmore 24 in. 16534 Built-in Dishwasher
It is most likely the flip spring...you need to be certain that the legs of the spring are inside the door edge and the spring does not swing freely...and there must be tension on the spring so that when the latch releases the door flips...you can also try this with an elastic, put the elastic inside the closed door and up around the drying solution knob, this will let the door flip open showing that the latch does work
Nov 11, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore Dishwasher Problems
Just for the degergent item.....The Sears repairman told me to not use the gel type detergent but only use cascade complete and to use very little of it..
Oct 19, 2007 | Kenmore 24 in. 16182 / 16189 Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
80 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
