Question about GE JSP69 Electric Kitchen Range
GE Model JSP69WvWW Bake element does not heat.
When the temp is set to desired temp on bake after a few seconds the display changes to 100 temp and symbol "ON" but element will not heat. When I removed the old element, the connection on the right side came out fine but on the left side about 2 inches of yellow wire came out, I slid the connection on wire from element and continued to replace element but get the same results as with old element.
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
jsrock516
  • 5911 Answers
SOURCE: oven bake element
If you're talking about the wires attached to the BAKE element, normally RED is on the RIGHT and YELLOW is on the LEFT, but it really doesn't matter. Theoretically, this is a resistive heating coil and it will work with the wires connected in either direction. Normally, its fairly easy to determine how these wires reconnect, because the lengths are normally only sufficient enough to connect them one way.
The RED wire connects from the BAKE element to the terminal block, to one side of the BROIL element. The YELLOW wire is connected to one end of the BAKE element and runs to the electronic oven control (EOC) board.
I hope this clarifies this for you.
Posted on Aug 23, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
  • 126 Answers
SOURCE: No Bake; everything else works
Most likely a bad bake igniter wb13t10045 cant guaruntee thats the problem but I'd start there.
Posted on Jan 28, 2009
  • 969 Answers
SOURCE: Need to replace bake element in GE oven model
LOOK FOR SCREW ATTACHING ELEMENT TO BACK OF OVEN INSIDE OVEN, REMOVE SCREWS, SLIP OFF WIRES. MAKE SURE POWER OFF!!!
Posted on Nov 12, 2009
Why does my GE Profile Trivection oven model JT930SH1SS not heat when turned on?
try looking at this...
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/11-3-616678-/new/GE-Oven-not-heating-JT930SH1SS
a call to them may resolve any questions you have.
best to you hope this helps a little...sorry for late reply.
Jan 23, 2018 | GE Ovens
Oven warms to desired temp then cools down
Check your bake element. Unually ovens use both bake and broil elements to preheat and just bake element to keep temperature. Your bake element is probably burned out.
Jan 30, 2011 | GE Profile JT912 Electric Single Oven
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
After temp is set bottom oven will not heat up to desired temp
you probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Jan 28, 2009 | Maytag MER6772 Gemini Electric Kitchen...
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Nov 25, 2007 | GE JRS04 Electric Single Oven
GE JSP69 Electric Kitchen Range Logo
223 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
