Question about Microwave Ovens
I accidently forgot and left a twist tie on, put it in the microwave and well now, you guessed it-- not heating. Any advice
    President:
  • 1,952 Answers
CHECK THE HEATING ELEMENTS
Posted on Jan 31, 2010
Arcing and flashing during cooking cycle
Arcing and flashing either has to do with having metal parts inside that are not chromed perfectly (better yet only put metal in if it's a microwave convection oven on convection setting only), or some of the powder coating on the inside of the cabinet is damaged. Or a twist tie etc was inside during use. If the cabinet is damaged dispose of unit.
Oct 20, 2013 | GE Adora Over the Range Microwave....
I have a GE HVM1750SM1SS and was defrosting some bread without seeing that there was a metal twist tie on the wrapper. In only a few seconds the plastic on the top started to melt and drip in the oven....
It sounds like you may be talking about the stirrer cover.
For some models, the owner's manual covers how to remove it. You can download GE owner's manuals and installation instructions here.
Otherwise, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 27, 2011 | GE HVM1750SMSS Microwave Oven
How do I twist the light bulb to remove it? it seems very tight and unmovable.
This is pretty common and can be a pain. It's tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
You could heat it up (hair dryer, maybe?) but be careful if heating so you don't burn anything.
I like to put a little WD-40 or rust buster on the threads of the new bulb, too. Grease, Vaseline, cooking oil, or anything like that will work. Just a thin coat.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven heats, but makes strange crackling noises. Is it allright to keep using the unit?
No. Please have it checkd as it is dangerous to let the high voltage jump along side the magnetron. This will eventually result in the failure of the magnetron with a possible damage to the circuits.
So open and check if there is any foreign particles/insects struck within , Is the insulation damaged or remove the magnetron and clean the uni , clean the cabin specially if food haas accidently got spurted inside, dry the whole unit after cleaning before you fix back the magnetron.
The microwave must now work without crackling or else if the spark is seem near the magnetron , it must be replaced.
Hope this advice helps.
Aug 27, 2010 | Microwave Ovens
Microwave lights and buttons work but doesn't heat up anything
When you start the microwave say for 1 minute. Listen closely when you hit start, the light should come on and about a 1/2 second later you should hear a little click and a slight hum. This means the controller is turning on the high voltage transformer and that part of it is working. My guess is that the magnatron is bad. That's the most common problems with all brands of microwaves. The mat on the top should not have caused the problem since the microwave has heat shutdowns in it. I would say that it's a 90% chance it's the magnatron. Most microwaves have a 5 year warranty on that part. Look at your owners manual. Good luck.
Scott
Jan 23, 2009 | Amana Radarange Microwave Oven
Sharp R-202EW microwave croaking- roller needs replacing?
You could remove the new turntable support but without replacing it (part # FROLPA101WRKZ) you just won't get even heating.
One option might be to remove the support, place in another (larger) glass tray or other microwave safe plate upside-down, then put the existing tray on top of that.
That will raise the food up. Then be sure you don;t place the food in the center. It will heat better if it's a little left of center.
Nov 04, 2008 | Sharp R-202EW Microwave Oven
Kenmore 89942 Microwave no longer heating food
Grass...I'd go for checking the fuses and the thermosensor...a black plastic button with two wires coming out of it that is about the diameter of a dime and 3/8 inch thick. If either is open, no power to the magnetron. Your unit may have a diagram inside. Have a look. The magnetron...? I doubt it.
Dec 16, 2007 | Kenmore 80882 Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
