Question about Sony VAIO VGN-A270P Notebook
I was gifted with a Sony Vaio VGN A270P laptop. What I "want" to do is max the RAM out to the 2GB that is allowable and replace the hard drive with either a solid state, or "standard" 360GB hard drive then load a linux OS and use the machine for school, iPod management, internet surfing and various other lightweight uses . This is the thing, as I understand it, 100GB was the largest drive that was available with this particular machine. Is what I propose doable? And if so....any suggestions as to particular sources, pitfalls, and other errata I would need to be aware of?
    Scholar:
  • 154 Answers
VAIO computer does not have drivers that will work for linux os.. they only work with windows,,
you can also upgrade the memory up to 2gb..
you can get the specifications from here user manual
goodluckü
Posted on Apr 10, 2010
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Can i put 4 gig ram in sony vaio VGN-C190P ? i have done but i doesn't work! what i can do?
got to www.crucial.com and either run their system scan tool or input your model. Our initial lookup shows the max for your system at 2048MB (2GB)
Apr 17, 2010 | Sony VAIO VGN-C190P PC Notebook
Display flickers on boot. then goes black
Before making any decision on whether it's a hardware failure, please try and boot from a CD or DVD (recovery disc). If it does successfully boot from an external disc - and there is no flickering problem, then the hardware parts are okay. In that case, please go to this link: http://lifehacker.com/5413223/how-to-fix-your-relatives-terrible-computer?skyline=true&s=x for more information on what to do when you can't enter into your operating system and how to fix malwares that might be causing the flickering. If you find my ideas satisfactory, please do rate me. Thanks
Jan 23, 2010 | Sony VAIO VGN-A270P Notebook
Sony VAIO VGN-250E/B upgrade memorey, will it take up too 4gb?
No the Sony VAIO VGN-250E/B has a maximum capacity of 2GB DDR2 RAM.
Oct 13, 2009 | Sony VAIO VGN-N250E/B Notebook
Replacing dvd in Sonly laptop.
Always remove battery first.
You have to flip it over and remove more screws from the front! See if this diagram can be of help to you:
http://losercoalition.net/blog/2008/03/sony-s-series-laptop-disassembly-for.html
Jun 12, 2009 | Sony VAIO VGN-A270P Notebook
MEMORY UPGRADE
from the white page I found:
"The 17-inch widescreen Sony Vaio VGN-AR230G, the first entertainment Sony’s AR notebook with Core 2 Duo Mobile (Merom) processor, is now available at SonyStyle.com. The Vaio VGN-AR230G comes with a T5600 (1.83GHz, 2MB L2 cache) CPU, an 1GB DDR2 SDRAM (expandable to maximal 2GB), an 200GB 4200rpm SATA hard drive and a dual layer DVD burner ."
There u are, only 2GB.
/Teis
Dec 29, 2008 | Sony VAIO VGN-AR230G Notebook
Sony VAIO VGN-A270P Notebook Logo
93 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
