Question about Lexmark X5470 All-In-One InkJet Printer
Open Door My printer keeps saying cover open even though the cover is closed. After turning it off and on, leaving it on for several hours, having it unplugged for several hours, and closing the lid several times it still comes up with the message. What can I do to reset it so it will print again??
  • Official Brand Answer
  • 3,344 Answers
Hi, here is something that you can try http://bit.ly/bHHnnO
Posted on Feb 09, 2010
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 08, 2016 | Office Equipment & Supplies
The screen states "close cover E" It is closed but the screen keeps saying " close cover E" ?
The Exit 2 interlock switch is either broken or off it's base or defective. If you open up the top door on left side of print, there is a push button switch that mounts on the back side. If you're standing on the left side of printer it's located on the top left. Make sure it's mounted properly and try to push the button with your finger and see if error goes away, if not replace switch, part number 110E11580.
http://www.iteminconline.com/110e11580_xerox-5500-door-b-interlock-switch.htm
Sep 23, 2015 | Xerox WorkCentre Pro 123/128 Printer
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Hi, my printer keeps saying cover open even though it is not have opened printer up but do not know which way back to put the white piece thanks
Remove the sheets of paper. Open the printer cover and remove the cartridges as well. Close the cover. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Load some paper. Check for any error. Try to print.
Apr 11, 2011 | Lexmark X3480 All-In-One Printer
Keeps giving message lid is open even though its closed
Door switch broken.
What door says it is open?? That switch can be crusted and don't make connection.
But first see with all your attention whith eyes wide open. You don't want to call assistance to just close doors, are you??? LOL :)
Mar 01, 2011 | Ricoh Aficio 2035 Copier
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Printer won't print - says door is closed, even when it's open
your door open sensor is not working proper.pls close this cover tightly..
Aug 16, 2009 | Office Equipment & Supplies
The resume button keeps flashing even after I shut off printer, and won't allow me to print. I turned off and on the printer several times. I don't get an error message. All ink is OK.
Make sure the ink cartridge cover is properly closed.
My sister's printer had a similar problem and on initial inspection the cover seemed to be closed, however a small bit of the plastic clip that holds the cover closed had snapped off and therefore wasn't holding the cover properly closed and the sensing micro switch that tells the printer the hatch is closed wasn't being activated.
Not very scientific and a bit of a bodge, but some suitably placed selotape / duct tape / insulating tape to hold the cover firmly closed did the trick.
Hope this helps.
Aug 11, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Back cover open message
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
Sep 02, 2008 | Brother MFC-7820N Printer
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
Lexmark X5470 All-In-One InkJet Printer Logo
91 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
