Question about Westinghouse WWSR1 Iron
I have all the parts for the Westinghouse WWSR1 Iron as new except the iron. The temperature limit switch had failed open and we never took it back for a replacement. All parts never used, iron was thrown away. Will send any parts you need for cost of shipping
2 Suggested Answers
SOURCE: replace filter beads
how do I open the compartment to replace the filter beads for my iron?
Posted on Mar 05, 2010
My panasonic NI22AWTXJ iron is not powering
Get a multimeter. Check that the fuse is OK. If it is ok, open the cover at the back of the iron. Plug in the iron. Be careful not to get electrocuted. Check that the cables from the socket on the wall have power. place the leads of the multimeter on the live and neutral and check for 240V or 110v depending on your country. If no power here cable could have a problem.
If there is power here, turn of power and unplug socket. open top cover, you will see the heating element. Check for continuity between the ends of the element, If no continuity the element is dead and you need to buy a new iron. If it has continuity then check continuity of other components connected in series with the element. Some models a limit thermostat to prevent the iron from over heating. This looks like a small resistor about one centimeter long, if it has no continuity, cut it off and bypass it. It is a safety device that fails when it senses high temperatures in case the main control thermostat fails. If you can find a replacement replace it, if you cant find a replacement, you can use it and hope the main thermostat does not fail.
Jun 22, 2017 | Panasonic Irons
I have a 4045 model iron, extremely happy with it. Recently, when I plug in the iron the light goes on but it does not heat up at all. Any way to fix it or is it busted. Suggestions would be appreciated.
Heatman101 posted this on the site......
"If you go to use your Electric Iron and it does not work you may be wondering what could have gone wrong. Actually there are only a few things that can go wrong with this handy little appliance.
The first thing to check is to make sure that you actually have electric power getting to the steam iron. Many times the problem is simply caused by a tripped circuit breaker, a faulty outlet, a worn or broken plug on the end of the cord, or in some cases, a fuse that is in the plug. Another common problem is for the cord of the clothing iron to break at the point where it enters the handle of the iron. By checking that you have power actually getting to the internal parts of the electric iron, you eliminate one set of common problems.
Next you need to check that the power is getting to the heating element. For the power to get to the heating elements of the iron it needs to go through the power switch and the thermostat. On some irons the power switch will be included in the iron thermostat and on others the on/off switch will be a separate switch. In either case you will need to make sure that there is continuity, or the ability for the power to flow through the switch and thermostat to get to the heating part of the iron. The thermostat is just an on/off switch that works on the temperature of the base of the iron. So whenever the iron is cold the thermostat should be closed, allowing the power to flow through it.
If the power can get to the heating element of the iron, then it should get hot. If it is not, then the heating part has failed. Sometimes, when this happens it will short out and cause the fuse to blow or the circuit breaker to trip. Many times though, the element will just simply burn out or break so that the circuit is open and the electricity cannot flow through to make the element produce heat.
If your iron is getting too hot or not hot enough then the problem will almost always be in the thermostat. Sometimes it may be a simple thermostat calibration problem, but it also can be that the thermostat simply will not work properly anymore.
This should give you a basic troubleshooting guide for home electric irons and steam irons. As you can see, there are not many parts that can fail and troubleshooting the few parts that can fail, is relatively simple with a basic electric meter."
Sounds like either power isn't getting to the heating element, or the element is bad.
Good Luck
--HomeGrown
Dec 29, 2010 | Sunbeam Euro Press 4045 Iron
The iron is dripping rusty water
this iron has had it . it has rusted throuh the element and the rust s iron oxide . .. not repairable .. // replace it . as it will cost less .. mm
Jan 15, 2010 | Euro-Pro Shark GI490 Iron
OVerheats - no control-thermostat? Can this be replaced?
Yes but it is probably cheaper to buy a new iron
The days of repairing small appliances went out of the door some 15 years ago.
Minimum 1 hour labour charge plus the parts cost at whatever Westinghouse want to charge will be circa $40
You then have an iron with and old tank , and old element etc etc waiting to go wrong to cost you another fee
Dec 31, 2009 | Westinghouse WST5017 Iron
Black & Decker D 1500 doesn't heat up - error message
For safety purposes, just about any electrical device that heats will have a thermal fuse built into them to prevent fires and these (ALL Chinese) are very poorly made and unreliable in operation. The design temperature is only rarely the same as the actual temperature at which the devices go open and interrupt current. Sometimes, the design temperature is printed on these fuses and they are available as replacement parts but are almost always welded in place and are not practically replaceable. If someone bothers to open the iron, look for a metal tube ~ 3/4" long and 1/4" in diameter with one end wire obviously connected to the case of the fuse and the other centered in a glass seal.
I once had three identical coffee makers fail within a few days of being new and finally took a refund instead of trying a fourth one.
Oct 03, 2009 | Black & Decker Irons
Switch light goes on when pressed but goes off if not pressed
Switch light goes on when pressed but goes off if... OR iron does not heat at all even pressing the button to turn it on continually.
Don't understand which one question you are asking
But if there is no heat at all after switching it on, it needs to go to iron heaven but be sure to cut the plug of the end, Saftey reasons at the dump. BUT if lights are coming on the iron is working. the large dial on the water filler is temperature control. Turn this around to cotton or linen.
The light will come on and off while in use, it allows you to know that the iron has cooled and is going back to your select temperature( on the large dial)
Make sure that you use water in the iron as it will aid your ironing and make it quicker. Make sure that the iron temperature dial on the water filler is at the correct temperature for the item that you are ironing.
Hope this helps
Sep 17, 2009 | Black & Decker Steam Xpress AS250 Iron...
Replace filter beads
Jul 30, 2009 | Westinghouse WWSR1 Iron
I need to buy the water tank, but cant it online.
Model has been discontinued. But they have some parts in stock. My iron assemble won't turn on anymore, but everything else works. They can't help me, but maybe they can help you. 1800-233-9054
Oct 25, 2007 | Westinghouse WWSR1 Iron
How to
Model has been dc'd. But they may have some parts left. They couldn't replace my iron assembly. Very bummed.
1-800-233-9054 customer service
Sep 03, 2007 | Westinghouse WWSR1 Iron
Westinghouse WWSR1 Iron Logo
47 people viewed this question
Top Westinghouse Irons Experts
Are you a Westinghouse Iron Expert? Answer questions, earn points and help others
