Question about RCA DRC8335
The machine has HELLO but will not start up. if i hold the on/standbye for a few seconds, the time will appear and then back to hello when I press play. All I did was put a tape in which I can not now remove TX
Hello everyone having problems with there RCA DRC8335. If you are getting the HELLO sign and nothing else(which i was too).
First you have to find the blown capacitor. All the capacitors should have a flat top. If you find one that is not flat and if gets hot to the touch when your vhs/dvd player has power you found your source. Next unplug your dvd/vhs player and take out the blown capacitor. Do not waste your money tring to get it fix by a so call pro. The parts you need is less than .55 cents(lol). Now the capacitor that you take out should have a code number(mine was c226) which is located in the same area as the blown part. Measure the capacitor and call for your part number 1-800-344-4539 Digi-key.com will find the part you need(only if u know what part u need)
1.find the blown capacitor
2.remove it
3.get the number below the blown capacitor
4. measure it.
5.call for your part number
6.put your hard earn dollar(not dollars) to work
7.and you can say Thanks Maximilian Moore for saving me money
Posted on Apr 16, 2010
  • 1 more comment
  • Mr_TVain Dec 01, 2010
    The capacitor that I had to replace was c226 (as your looking at the back of the unit, its on the right hand board that the power supply goes into... but its most of the way at the top left portion of that board as you are looking down on it - the capacitor is labeled on the actual orange board). I read on another post from another user that had to do this with a bunch of these DRC8335 units and he replaced the capacitor with a 35v 470 uf (the one that it comes with is 16v 470 uf). I went to radio shack and paid $1.35 for the capacitor (I purchased two in case of the probable screw up) and $6.49 for a 5pc Soldering Iron kit. I yanked that old capacitor out (leaving the metal prongs) and soldered the prongs of the new capacitor to the leavings of the old one... it looked a little ghetto by the time I was done, but by god, it worked!
  • jrbl995 Mar 23, 2011
    I've taken the unit apart... found the c226 capacitor... it doesn't look especially bulgy... (nearby c228 looks pretty much exactly the same) and it MAYBE gets a little warm. I've had it plugged in for about an hour. Will it take longer to get hot? None of the other capacitors look bulged of feel hot. However the thing that looks like a cylinder sitting vertically in the middle of a hans solo carbonite frame with yellow and copper tape around it seems to be making a very soft buzzing noise... or at least one of it's neighbors near the middle of the board. The heat sink next to that is getting pretty hot... but I guess they're supposed to. What is the hans solo thing and might it be the cause of trouble? Should I just go ahead a replace the c226 and see if that fixes it? I'll have to have a friend help me with the soldering.
  • Charles Sitz Sep 24, 2011
    Very good detailed help. I did just what you said buying the 35 volt replacement at Radio Shack and am back in business now. It was an easy fix. Thanks! You saved me a lot of $$$$$.
  • 8 Answers
You have a blown capacitor in your machine. If you are good with a soldering iron, great, you can fix it yourself. Otherwise, find a friend who is good with a soldering iron. Parts should cost you less than $2 for a new capacitor. Replaced the blown capacitor in my machine, and my tape popped out with no fuss once I powered the system back up.
Posted on Mar 14, 2010
  • Gonzojim Aug 28, 2010
    Thanks,I did exactly what you said and badda boom I'm back in business. Kudos!
Hello, I have a Paradigm T801 showing the error message ERR 40 Over Acceleration. Is there any easy fix for that problem?
Reset the machine and proceed wit this steps. God bles you
1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
Oct 02, 2013 | Paradigm Exercise & Fitness
The washer comes up "TEST" instead of the
Hello & Welcome to FixYa
Someone accidentally put it into TEST mode and to get it out of the test mode follow this:-- Unplug the washer for 4 minutes and then plug it back and press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius is coming up with test and will not start when I have gone to use it it came up with the time and temperature but then it just said test and will not move on
hello try this Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work. hope it helps
regards
shaun
Jan 08, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My washer is digital, and at the moment every time i press start it says test can u help me
hello, Someone has accidentally pressed some buttons and locked you into test mode.
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi, my front loader washing machine (Bosch Logixx 8 sensitive) has child lock written on the screen and will not start the load. ive tried switching it on and off again but it does nothing. the door is...
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Dec 22, 2010 | Bosch Washing Machines
I have factory unlock iphone 3g my problem is when i charging
try these resets:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
f iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jul 27, 2009 | Apple iPhone Smartphone
My washing machine keeps coming up test can you help me
Hello Lainy34,
Give this a try, turn off then back on. When on appears on the screen press and hold the "start/cancel" and the "on/off" at the same time until "D:off" appears in the display. It should be back to normal after that. Hope this fixes it for you.
Thanks,
edgin96
May 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
When i open my camera eithrer for still or video, the camera is not working, its getting hanged,,,
Hello sathar2002,
Try this first:
Press and hold the Sleep/Wake (on top of the iphone) button for a few seconds until the red slider appears, then slide the slider. The phone will turn off. Then, push and hold it again, until the phone comes back on.
If that doesn't work, try this:
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears. This will do a "hard reset" and should bring your iphone back to life!
Please let us know how this works for you.
Best regards,
Bill
Feb 21, 2009 | Apple iPhone Smartphone
I cannot connect to YouTube,safari crashes and i have no sound. Everything was ok a few days ago. My iphone is new 2 weeks. I feel like screaming pls help
Hello belito33,
Try this first:
If these solutions don't work for you, take your phone back, you have 30 days to return it for a brand new phone.
Best regards,
Bill
IPhone
Hello Bruce,
Try this first:
Best regards,
Bill
May 30, 2008 | Apple iPhone Smartphone
RCA DRC8335 Logo
2,197 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
