Question about Janome Sewing Machines
My machine won't sew . I have rethreaded, taken the bobbin out and cleaned it but still sews on one spot without moving
  • 25 Answers
You have probably got the feed dogs down
Posted on Feb 11, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
Bobbin stopped turning. I rethreaded it and unplugged it and turned it back on. Now it does nothing but sound like it's trying to sew and there is a message in the little window that looks like a backwards...
have you taken out the bobbin case and all the parts around the bobbin? sometimes lint and threads can get stuck in there and throw off the timing of how everything works. There is not a lot of room for error with all of those moving parts. Possibly put ONE drop of sewing machine oil on the center spindle of the bobbin compartment. You might want to check to see if there is anything in the way of the gears moving also. Sounds like what my brother embroidery machine does if there is gunk in the gears. good luck
Sep 16, 2013 | Singer Sewing Co 7258.CL Stylist Sewing...
I have a Necchi 4900 and the thread catches on the bobbin holder , moves the bobbin holder out of place , james , have taken it out cleaned everthing under the bobbin and takewn the underneath cover
try changing the needle to see if that helps
if it doesn't,, then I suggest that the sewing machine be checked
at a repair shop to see if the bobbin case needs to be replaced and
to see if the hook and the hook race need to be replaced
Nov 01, 2012 | Necchi Sewing Machines
My BV 160 is giving me problems. The fabric will not move along as I sew. I hve ck'd the feed dogs, they're ok, rethreaded the needle, bobbin, cleaned the bobbin but still not sewing.
have you checked the presser foot to see if the presser foot is holding
the fabric against the feed dogs so they can move the fabric thru to
be sewn by the needle?
Jun 07, 2012 | Bernina Virtuosa 160
Singer sewing machine won't pick up bobbin thread
Make sure that the area is clean and free of lint. Change the needle and rethread the machine.
Nov 24, 2011 | Singer 7426 Mechanical Sewing Machine
After only one or two stitches the thread catches a bunch down where the bobbin is located. Is this the timing, if it is what can be done about it. how does one change the timing?
try rethreading the machine top & bobbin
make sure the bobbin area is clean of lint or loose thread
make sure the bobbin is not warped
change the needle in case it's bent or blunt
if no suggestions work, then the machine would have to be taken to a repair shop to be serviced & the timing check, they have the tools needed
Nov 02, 2010 | White Sewing 1866 Mechanical Sewing...
The needle on my sewing machine will not move up and down, the handwheel is a little tight and the bobbin winder wont move, how do I fix this?
You are jammed up with thread or material. Clean it out, rethread, wind a new bobbin. Oil your machine and put in a new needle. When you sew, hold the thread ends when you first start out sewing for about 4-5 stitches. Read your manual, watch your dvd on instructions
Oct 21, 2010 | Singer 3116 Simple
I was sewing an overlock stitch and it just stopped pulling the bobbin thread through. I think the timing got messed up. I have switched needles and that didn't fix the problem. How can I fix the timing...
A suggestion to try:
Remove all the thread from the machine.
Check for and clean out any thread pieces, lint, etc. in the bobbin area.
ALWAYS RAISE the presser foot and rethread the top thread--verify the thread path is correct.
Rethread and install the bobbin in the machine.
Retest the machine.
Feb 13, 2018 | Singer Curvy 8770 Electronic Sewing...
I am getting a very loose stitch along the bottom, but when I turn the resistance up, the machine binds up. The needle won t move, and the thread tension is well beyond what would seem normal. I had no...
Try rethreading the machine, and make sure your bobbin is in the right way - check the manual.Also clean out under the needle plate- a build up of lint can cause all kinds of trouble.
Feb 12, 2010 | Singer 5050 Mechanical Sewing Machine
My sewing machine bobbin won't spin to rethread the bobbin.
is the area free from any dust or threads? when was the last time you had oiled your machine?
May 12, 2009 | Sewing Machines
Sewing Machines Logo
48 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
