Question about Imperial IFS40 Deep Fryer
Pilot won't stay lit - Imperial IFS40 Deep Fryer
    Problem Solver:
  • 18 Answers
Please provide more info. Does it stay lit after you release the button on the gas valve or does it stay on for awhile and then go out.
Posted on Feb 22, 2010
Pilot lite won't stay lit
Thermostat flame sensor. Do you see a little rod next to the pilot? That is what tells the main gas valve that the pilot is lit and it is safe to give gas. Easy swap, and you can usually just pick up a generic one.
Apr 14, 2013 | Heating & Cooling
Pilot won't stay lit...gaffers&sattler model B35
Hit the flame sensor next to the pilot with sandpaper. If it still doesn't work replace it.
Feb 26, 2013 | Heating & Cooling
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
Dec 19, 2012 | Heating & Cooling
Pilot light won't stay on
What is the model number of the unit?
Nov 27, 2012 | Tappan Kitchen Ranges
Model Ga3400T Pilot won't stay lit
This is caused in most cases by a defective gas valve thermal probe.
Dec 01, 2011 | Heating & Cooling
Pilot won't stay lit on furnace
Is that pilot automatic? If so then a quick easy fix for this is to located the sensor and replace it or clean it up with sand paper. After ignition the control is looking for verification of ignition from that sensor. How to videos
Sep 30, 2011 | Heating & Cooling
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
Pilot won't stay lit, replaced thermalcouple but
I would remove pilot light assembly and clean orifice and blow out gas line to pilot. Check to see that thermocouple is centered in pilot flame. It is possiblethat your gas valve is bad but it is also possible that you got a defective thermocouple. I would change the thermocouple again as they are much less expensive then the gas valves. The next time when you are sure you have the thernocouple mounted as close to the center of the pilot flame hold the pilot button down for several mins. If none of this works then you may have to change your gas valve.Thank you.
May 06, 2011 | Rheem Water Heaters
Imperial IFS40 Deep Fryer Logo
158 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
