Question about Canon ImageClass D880 Copier
Is the fixing film part of the fusing unit or can it be replaced separately
    President:
  • 3,085 Answers
Generally, if the film is worn, so are the other parts in the fuser. I recommend replacing the the entire fuser.
Posted on Jan 31, 2010
Help me how to remove system error cod e000 for canon pc-d 340
PC-D320/PC-D340/FAX-L400 Chapter 4: Maintenance and Service
E000 Fixing unit failure
Cause: (1) Shorted/broken wired main thermistor (2) Shorted/broken wired sub thermistor (3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-2 (FSRTH) and J206-1 (GND). If the resistance is not within the range between 350 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (2) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-3 (FSRTH2) and J206-4 (+3.3V). If the resistance is not within the range between 370 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (3) With the fixing film unit removed, if there is no continuity between the fixing unit connectors J102-1 (ACH) and J102-2 (ACN), replace the fixing film unit. (4) Replace the ECNT board. (5) Replace the SCNT board
See Service Manual page 105 (4-25):
Canon PC D320 Service Manual Page 105
Jun 04, 2015 | Canon PC-D340 All-In-One Laser Printer
Error code e000 0000
If Error code is E000 then may be major cause:
+ The thermistor has an open circuit or short curcuit
+ The heater has an open circut. The thermal fuse has blown
+ The power supply PCB has a fault
+ The engine controller PCB has a fault
To Fix Error code E000 of Canon LassetJet LBP-3300 printer, you can try the following:
+ Check connector of the fixing film unit
+ Replace the fixing film unit
+ Replace the power supply PCB
+ Replace the engine controller PCB
This is not a job for a novice. Get a service technician to service the unit.
Apr 23, 2014 | Canon LBP3300
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
Canon gp225 with error code e0007-01 reset it but came back again
I'm not sure what a gp225 is, but the error code E007 deals with the fusing unit. It means that the fuser film can not find Home Postion. Basicly the film has moved out of place or the film is damaged and moved out of hp. Basicly,to solve the problem the fuser film needs to be replaced. Good Luck
Aug 22, 2010 | Canon Office Equipment & Supplies
Code E007
What type of device are you getting the error on?
For a NP-6016
Code indicates damaged fixing film, but often is caused by the rear of the machine latching completely when clamshell is closed. This causes the gears that drive the film to not quite mesh, so the film doesn't move, or moves too slowly. This usually happens on ADF models, as they have heavier shocks for the **** Shell. Before replacing film, which is a pain, try pushing down on left rear corner of machine to see if it runs.
E007 fixing unit fault in the uper fusing unit of a canon np-6016 needs new upper fixing belt or fixing unit
Jun 24, 2010 | Office Equipment & Supplies
System error 004
E004 Fixing unit failure
E100 Scanner unit failure
E246 The Counter board is left out
E676 Communication error
E677/6F-61 ROM check error
E677/6F-63 RAM error
E733 A fault occurred in the communication between the SCNT board
and ECU board/TOP signal cannot be detected
New E805 Fan failure
TRY THIS:
Measure the resistance between the fixing unit connector J301-1
(FSRTH) and J301-2 (GND).
If the resistance is not within the range between 350 W and 520 W
Measure the resistance between the fixing unit connector J302-1
(FSRTH2) and J302-2 (GND).
If the resistance is not within the range between 360 W and 530 W
between the fixing unit connectors J303-1 (ACN) and J303-3
(ACH), replace the fixing film unit.
(4) Replace the EPU board.
(5) Replace the ECU board.
Jun 24, 2010 | Canon Office Equipment & Supplies
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
E-000003-0000
During printing, the main thermistor detects less than 120°C/248°F for 1
sec or more continuously.
Main cause:
The fixing film unit is faulty (main thermistor fault, thermal fuse blow, fix-
ing heater fault).
Or the power supply PCB is faulty.
Or the DC controller PCB is faulty.
Action1.
Malfunction
Turn off the power; wait for 10 min, and turn on the power. Is the problem
corrected?
YES:End.
2.Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO:Correct the wiring.
3.Fixing film unit
Try replacing the fixing film unit.
Is the problem corrected?
YES:End.
4.Power supply PCB, DC controller PCB
Try replacing the power supply PCB. Is the problem corrected?
YES:End.
NO:Replace the DC controller PCB
Nov 07, 2009 | Canon imageCLASS D320 Digital Copier
System error E007
my copier have a system error e0007
Jun 10, 2009 | Sharp AR-M350N Copier
Canon ImageClass D880 Copier Logo
103 people viewed this question
old marine
old marine
