Question about Sharp AR-5316 Advanced Digital Imager Copier
Problem synbole i have the sympole of alarmes indicator(the photo of man) wat means and how repair it
  • obwoya Feb 26, 2008
    when i power up my copier it intialises fully but after displays a photo of a man and shows a developer sign.
  • 71 Answers
It means it needs a service call.
Are there any numbers or letters on the display, like H4?
Posted on Feb 19, 2008
Konika 7130 f 26-3
Posted on Jul 02, 2008
:). meaning
ok this means smiling and just to help you more here is a site you can get all the symbols and meanings.
Sep 03, 2014 | Computers & Internet
I unlocked my door and when i opened it the alarm started goin off so i tried to crank it ro get it to stop amd it didnt so i have took the fuse out and undone the battery and hooked it back u p and...
Go to your passenger door and use your key on that door to unlock it. If its like a Nissan Quest I once had this should solve your problem.
Aug 16, 2014 | Cars & Trucks
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
My nokia 6300 always restart every after 2min..wat sall i
reset factory your cell if not ok watch dog is on it means the super dongle of your cell corrupted can repair by a repair man
Aug 03, 2011 | Nokia 6300 Cellular Phone
I have a Casio 50M. I can't stop the alarm function. It seems to beep when it wants to. This watch has the REM feature. Help !!!
Hi trapmanjohn,
Man what an aggravating problem! Try this procedure.
1. To turn the daily alarm and time signal on and off:
2. In the Alarm mode, press "B" , upper right button, to cycle throught the on and off settings as follows:
Alarm on Indicator/Hourly Time Signal On Indicator
a. }}}} with Bell = Both alarms on
b. Display Blank = Both alarms OFF
c. }}}} = Daily alarm on only
d. Bell = Hourly time signal on only
The Alarm ( }}}} ) indicator flashes while the alarm is sounding.
The Alarm ( }}}} ) indicator and hourly time signal on BELL indicator are displayed in all modes.
To Test The Alarm: In Alarm Mode, hold down the "B" to sound the alarm.
Your Module number is #3171. Down an Operation Guide for the 3171 from here for more clarity:
This should help you with nuisance...Good luck.
Regards, Bill
Sep 08, 2010 | Watches
There is an unuasual symbol at the top of my phone looks like a calander with a small clock do u know what this means?
This symbol indicates that you have an upcoming scheduled appointment or call alarm. The phone has an icon glossary, which gives a poorly translated definition for each icon...
Press Menu/OK
select Settings (option 9)
select Phone Info (option *)
select Icon Glossary (option 2)
select the icon of interest and press Menu/OK
Sep 05, 2009 | Sanyo SCP-7050 Cellular Phone
My dvd says ps off wat does that mean
Hello, That message can be an indication that the power supply is failing and has not gone completely bad. This could be an indication of a failed component in the power supply. The fact that you are getting this message means the ps (power supply)has not completely failed. I would suggest taking it to a repair shop to have it looked at and repaired. I hope this helps, Thank you, Shuttle83
Jun 10, 2009 | Memorex MVD2022 DVD Player
Sharp AR-5316 Advanced Digital Imager Copier Logo
55 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
