Question about Kitchen Appliances - Others
We just bought a house with a Heatilator GCDC60 and when the fire is lit you can smell the gas a little because the blower/fan is not working. We have looked in the fire place and we can see the outlet where the fan plugs in, but we cannot tell where the actual cord to the fan is so we can plug it in. Thank you for any help you can give me.
Here is the part you are referring to:
http://www.electricmotorwarehouse.com/fireplace/R7-RB168B.htm
The cord should be connected on the backside of the blower. If not, you need another or replace the whole blower. Hope this helps.
Posted on Mar 08, 2010
My heatilator fireplace seems to have a closed flue but I cannot find one?
First of all, immediately install carbon monoxide detectors in all living areas of your home. You stated you smell gas? Call a plumber! He or she will verify if it's raw gas or not. What you probably meant to state is you smell the flue gas/combustibles. You'll need to have your flue piping connections/outlet checked.
Oct 17, 2017 | Heating & Cooling
Have a heatilator direct vent GC300ST 15+yrs pilot woont stay lit think I need a thermoplie where can I find ? thk you
You probably need a thermocouple. Any local fire log sales store typically has a thermocouple in stock. If your system has a thermopile as well and is 15+ years old, I'd suggest getting anew pilot assembly and installing it. This way all the parts are new and you won't have to replace another part in 6 months.
Feb 25, 2014 | Heatilator Home
Heatilator gcdc60 won't turn off unless I disconnect one of the thermostat lead wires or I move the control know on the Robershaw 7000 valve to "off". It burns fine, and fan comes on when it is...
From everything you tried to cover, the problem lies in the wall thermostat. Repairing it isn't a good option. Replacing it is fairly inexpensive to do. Just make sure you replace it with one of the same voltage. Or if it's a millivolt control valve on the heater, make sure the replacement is for millivolt operation.
Hope this helped you solve the problem.
Apr 25, 2011 | Williams 2509612 Ceramic Mid-Size Heater
I have a heatilator gas fireplace model gcdc60 and the flame is not high anymore. This fireplace has two settings low and high. The high setting is like having low on and the low setting is almost not...
Take a thin stiff wire and run it thru each flame port of the burner a few times each then if you can take a vacuum after setting it right on the ports-tap on the burner with a object while vacuuming it-if that does not work -is there a place that looks like a nut over each flame port? if so spray with a lubricant like WD40 to loose the nut and remove and clean flame ports that way and vacuum it then same way then
Sep 30, 2017 | Home
Turned blower fan on to vent the home. Sudenly it smelled like burning air throughout the house. Turned off the fan. Restarted and no problem. What's going on?
Sunbinder...you will need to do a little troubleshooting. Turn it off again and wait 20 minutes then back on. If no noise or odor. Are you certain that the smell came from the blower. "Thru-out the house is a lot of smell. Listen closely on startup and running....any unusual sounds. ? Which fan are you talking about ? Furnace ? Vent like bath or kitchen ? If you are handy you can check the wiring connections to be sure they are secure and making good contact with tight wirenuts or screws etc.
Jun 07, 2010 | Cross Furnace Draft Inducer Blower 115...
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Dec 24, 2008 | Heating & Cooling
Kitchen Appliances - Others Logo
591 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
