Question about LG VX8360 Cell Phone
I BROKE THE HEADPHONE JACK ON MY LG 8360 HOW DO I SOLDER THAT BACK TOGETHER
2 Suggested Answers
SOURCE: Have an LG G3 LS990. Headphone plug broke off in jack. Tried needlenose pliers, but that didn't work. Does anyone have any suggestions as to how I can remove it?
This tool is specifically for that priblem. The GripStick. https://youtu.be/Ii5OKvtNxe4
Posted on Jul 31, 2015
Testimonial: "Thanks all for great suggestions! I do like the removal tool. To chicken to use super glue."
Solder headphone jack
If the wires can be joined see the attached pics for re-joining, just connect the same colours together. Test them to make sure there are no other breaks in the wire. Then solder them together and seal with a waterproof tape or similar. DONT just tape them together this will lead to them coming apart easily.
If they came out of the jack it would be best if you bought a new jack and soldered the wires onto this. Trying to open a factory fitted jack is difficult and you wont be able to seal again properly unless you superglue the jack once you've reconnected it and test them to make sure there are no other breaks in the wire solder the wires to the jack. see attached pics for jack wiring.
Hope this helps
Nov 16, 2013 | ifrogz EarPollution Plugz Headphones
42LD520 sound shorts out
if it has a headphone jack it could cause this--the jack when inserted cuts off the speakers to engage a headphone--try inserting a jack when it does this and wiggle it a little--jack socket has leaf contacts that can be out of position
If tapping it could also be a bad solder connection somewhere.
Apr 08, 2012 | LG 42LD520 42 in. HD-Ready LCD TV
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
I have a pair of tp-1a headphones. The headphone jack broke off. What do I do to replace it.
If you want to fix it yourself go to partsexpress.com and buy a new headphone plug. You can go to radio shack, but their headphone plug is very large but you won't need to solder anything. Cut the wires and strip off the plastic. You will see very small wires coated in red and blue if I remember correctly. You will need to separate all little wires so the colors are together. The color coatings need to be removed. Put them in the flame of a lighter for just a quick second. The coating will burn off. Scratch off the excess with your fingernail.
You will need to plug the new headphone plug into an ipod and touch the wires to the connectors to figure out which wires are for the left and the right speakers.
Solder the wires to the new headphone jack. You will find the partsexpress jacks are much better than the original.
If you use the radio shack plug you may want to put a little hot glue with a glue gun around the wires before you close it put or the wires will pull out easily. The parts express plug, link below, has a tight grip on the wires and there is no need for glue.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=092-333
Dec 24, 2010 | Bose TRIPORTĀ® Headphones
The headphone jack broke. It is kind of pushed into the mixer. Is this repairable?
I repaired mine when that happened.... you have you unscrew all the screws on the top plare there is like 5 or 6 silver ones..Remove faders (2 volume 1 headphone) then remove the top plate. Then unscrew the the black screws on the side and front of the mixer... NOW THIS PART IS IMPORTANT..from the corners of the mixer there will be a little lifts carefully lift the top of the mixer up JUST A LITTLE BIT... have someone hold it or just rest it diagonally so you can unscrew the jack from the back MIC unless you were able to salvage the jack from the headphone if that silver and black piece are gone your going to have to borrow it from the mic... dont worry the mic will still be functional because its better set in that the headphone jack... now use the outside piece and bring the headphone component to the front where its suppose to be so you can screw the 2 back together.. then put every back together in a reverse order and you should be fine.... if you have anymore questions email me at DjAnthem222@yahoo.com
Sep 18, 2010 | Nu Mark Numark Dxm06 DJ Mixer With 12...
I got a Toshiba laptop satellite C655-05049 and accidentally the headphone port or jack broke , so I'd like to know what my options are to solve this problem , just to get it back new , should I buy the...
They come with 1-Year parts and labor warranty normally, so if you bought it less than a year ago, they might fix it for you! If you got it at Best Buy (for example) recently, take it in and ask.
If the headphone jack is attached to the motherboard then the only solution is to re-solder the jack (or a new jack) to the motherboard, if it has been detached. (I have tripped over a headphone cable once or twice and done this)
Hiring a tech to solder can be expensive and time consuming and it MIGHT be less expensive to replace the motherboard. If you are feeling tech-savvy yourself and know how to solder you may try to attach a new jack, since you know you will have to replace the motherboard anyway.
Unfortunately, your laptop does NOT have expansion slots, so the only way to add an another sound card would be USB external, which is very inconvenient for a laptop.
So YES. All things being equal, a new motherboard is your only option... that being said, attempting to fix the old one can only result in the same solution, at worst.
They come with 1-Year parts and labor, so if you bought it less than a year ago, they might fix it for you!
Sep 07, 2010 | Toshiba (4CH-VOUT) Sound Card
My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Aug 06, 2009 | Sony MDR-V700DJ Professional Headphones
Tdk mp100 headphone jack
Each of the rubber covered cords running to each ear piece has two fine strand wire bundles inside. The right ear piece has a red colored strand and a copper colored strand. The left ear piece has a green colored strand and a copper colored strand. The wires are coated with an insulation lacquer. The lacquer burns off when you heat the wire for soldering.
Repair item: 3.5 mm stereo headphone jack, shrink tubing
Plan for strain relief:. These headphone wires can't take any tension at all. You need to crimp the black cords to the headphone jack somehow.
Slide strain relief and headphone jack housing over the over the rubber covered headphone cord.
  • You need to plan a way to relieve the pulling stress on the solder joints where the two headphone cords enter your replacement headphone jack.
  • Try shrink tubing if you have it.
  • If you have some thermal shrink tubing, slide a piece over the headphone cord end before stripping the wires.
  • Slide the headphone jack casing over the headphone cord also.
Strip each headphone cord 5/8" using the 18 gage setting of your wire stripper..
Hold each headphone cord in a "third hand" soldering assist tool and tease the green, red and copper bundles apart..I wore a 10x Magnavisor and I used a sewing needle and a bright light.
Twist the copper colored strands from both headphone cords together. They are the common ground wires. The copper colored bundle will attach to the headphone jack ground.
Apply a dab of solder to the end of each of the three bundles of wire. You will see and smell the insulating lacquer as it burns off. Keep most of the wire bundle cool.
Position the two strand headphone cord and the 3.5 mm headphone jack in the third hand soldering stand.
  • Plan where you can crimp the headphone cord. Crimp it when ready.
  • The green == left channel wire goes to the tip of the 3.5mm jack.
  • The red==right channel wire goes to the middle of the 3.5 mm jack
  • The copper colored wires go to the ground of the jack..
  • Measure resistance, 31 ohms per earpiece.
  • Screw the jack cover on and finish the strain relief craftsmanship.
Nov 28, 2008 | TDK MP100 Professional Headphones
My pioneer djm 600 mixer has a fault where the headphones are not playing properly though each ear and doesnt sound quite right it is not the earphones
do some cleaning in headphone socket by apply spray contact cleaner in it----then insert headphone jack in---out many times after applying  the spray.
Sep 18, 2008 | Pioneer DJM-600 Silver Professional DJ...
MP3 PLAYERS ARE MADE CHEAPLY!
I have one that had the same problem. I solder the jack back on but noticed that the solder pad came off the circuit board. Look at the circuit board and find the component where the connection from the solder pad leads. Using a piece of wire you should be able make a new connection. even after Soldering the jack back on, check to see if the pads inside the jack are bulging out enough to connect to the headphones. The constant wear and tear from rocking the headphone jack back and forth is what causes it to "brake". Could happen when its on your pocket.
Apr 11, 2008 | Samsung YP-U2JQB MP3 Player
LG VX8360 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
